Originally Posted by timlangham
I did check the com port on my pc. However, I did not see the option in the software to change the com port withing the software. You were successful in uploading to your scanner?
What com port is indicated in Ports (Com & LPT)
No, I don't have the scanner, but the software went through the search for a port so it works a little different then my ARC500 software. But the search indicates if a port is assigned and the cable is connected firmly to the scanner, it will load. If not connected firmly to USB port, you won't find it listed in the Ports (Com & LPT).
