Old 07-21-2008, 11:36 PM
Send a message via AIM to cookmaster Send a message via Yahoo to cookmaster
Default Question about win 500
hope somone can help, i am trying to download my PSR-500 to win500. but when i push the download from scanner button it says waiting for scanner, and then i get another message that says timeout waiting for 67452 data bytes, received 0. what i am trying to do is download from PSR500 to win500. what happen was i delete a Conventional Frequency out of the PSR-500 and i need to get it back in the order it was in. 01-0001 freq 1, 01-0002 freq 2, deleted freq 3, 01-0004 freq 4. thanks all . Don S can you help me.
Old 07-21-2008, 11:44 PM
btritch's Avatar
Send a message via MSN to btritch Send a message via Yahoo to btritch
You need to go into the configuration tab, Then click on serial port, and make sure that you're USB port matches the COM PORT number, This is usually 3 or 6.. You can check to see what this is in your computer but I don't remember right off hand how.. Once you get this lined out, It should work fine for you, If you have anymore problems, Let us know.. Hope This Helps!
Brian
Paragould/Greene County Arkansas 72450
Online Area Scanner Feed: http://greene.ar.scanamerica.us/
Old 07-21-2008, 11:55 PM
it's still the same as was before, i will keep trying. the com port is fine it's comport 4.
Old 07-21-2008, 11:57 PM
Highpockets's Avatar
What version of the software are you using? Starting with v1.52 in configuration menu, click on find psr500/600 serial port, it will fine the com port for you and set it as your default.
Steve
BC780xlt ~ BC785D ~ BCD996XT ~ PSR600
Old 07-22-2008, 12:11 AM
i am using the First Version of win 500, again the comport is fine , it's working fine it's comport 4. thanks
Old 07-22-2008, 12:25 AM
is there any way to fix the problem without using win 500, like by hand. thanks
Old 07-22-2008, 01:49 AM
Smile Question about win 500
Thanks everyone, for all your help the Problem is fix now. again thanks all. Tyrone Peace out.
Similar Threads
Harris County STARNET PSR 500 WIN 500 - Spinter group raetex Texas Radio Discussion Forum 4 04-29-2008 02:02 PM
Win 500 File for Denver Metro Area k0pwo Colorado Radio Discussion Forum 4 03-15-2008 11:42 PM
gre 500 and win 500 trouble jonboy11 GRE Scanners 8 02-10-2008 12:27 AM
Radio shack Pro97 to PSR 500? Stavro35 GRE Scanners 3 01-05-2008 01:12 PM
Win 500 KC9GLG GRE Scanners 3 10-14-2007 10:50 AM
