Old 07-23-2008, 10:05 PM
Default Win500: No TSYS
Ok, I must have done something wrong, but I'm not quite sure how to correct it without starting over a new win500 file from scratch. Here's the problem:
When I scroll though the list of objects under the "ALL OBJECTS" tab, most of the talk group objects say "No TSYS" in the "Object info" column. As of yesterday all the TG objects had TSYS assigned to them. I was sorting the columns today and that's where I think I messed things up.
How do I get these objects assigned back to their respective trunking system?
Old 07-23-2008, 10:32 PM
Go to the "TSYS" tab. Check the "Show unassigned" box (between the TSYS and TGRP grids). Select all of the TGRP objects and then select "Cut" from the "Edit" menu (or, right-click in TGRP grid, select "Select All", right-click again and select "Cut"). Click on the correct TSYS in the top grid. Uncheck the "Show unassigned" box. Right-click in the TGRP grid and select "Paste" from the popup menu that appears.
I'll keep my freedom, my guns, and my money... you can keep the change
Old 07-24-2008, 10:12 AM
Thanks for your help Don. I will do that when I get home tonight. Much appreciated.
Similar Threads
PSR-500 Scan List "limitations" - possible workaround DonS GRE Scanners 16 05-10-2008 01:58 PM
PSR-500 multi-site roam settings scanfan03 GRE Scanners 59 04-24-2008 04:24 PM
Win500 not accepting P25 tables DaveNF2G Scanner Programming Software 7 04-15-2008 08:06 PM
WIN500 New TSYS Object --> TGRP Object prt7u Scanner Programming Software 2 03-27-2008 01:43 PM
Another 500/600 Qwirk joseph GRE Scanners 18 01-29-2008 07:43 PM
