Old 07-26-2008, 11:58 PM
Default arc15
I have a bct15 that i think is great, the scanner came pre programed with 5 quick systems loaded, I just purchased arc 15 on line, I have it downloaded, I think i have the jist of it figured out, I'm going on a road trip next weekend, my question is the systems that i want listen to, can i assign them quicksystem keys, like starting at 50, then putting group quick keys, or will the scanner just defualt to 6 key then 7 thru what ever, thanks
Old 07-27-2008, 08:10 AM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
You can assign any system quickkey number to your systems, by default the scanner will not assign a quickkey. In ARC15 click on the systemname in the 'systembrowser' and then in the right pane you can select the system quickkey.
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Become a BuTel Software affiliate! Check our website for details.
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 07-27-2008, 11:56 AM
Default arc15
I was able to program my test group, but i can not lockit out from my quick keys, I have 1-5 that came preloaded, i progrmmed my test to what i thought was qkey 50, Ihave quick groups working ok, But I cannot close out the 50, the bottom display shows 1-5 (preloaded)groups then shows S5:---------0, what did I do wrong?? thanks
Old 07-27-2008, 12:48 PM
Bucko's Avatar
Anything above 0 to 9 quick key you need to push the no button then your assigned quick key number ( while scanning) to unlock or lock.
Old 07-27-2008, 04:42 PM
Default arc15
thank you, that worked, I have to make a mental note, thanks again.
Old 07-27-2008, 06:49 PM
Bucko's Avatar
This easy to read manual maybe some help for you http://myweb.cableone.net/marksscann...T15/bct15.html
Similar Threads
FS: BCT-15 with disc tap and ARC15 Basic software jon124 Old Classifieds Archives 10 06-07-2008 11:13 AM
Butel Software Updates ARC15; ARC996; ARC3500 500C1 Scanner Programming Software 4 04-04-2008 05:35 AM
Butel's ARC15 Basic problem tonsoffun Scanner Programming Software 2 01-13-2008 07:59 PM
ARC15 software for BCT15 Butelsoftware Scanner Programming Software 5 08-12-2006 12:42 PM
