Originally Posted by ntnahed
I've got a BC250D with ARC250 and a Pro97 with my newly re-acquired Win97. I'm looking for the info to direct load freq's and TG's via RR. Can anyone point me in the right direction. Mostly interested in Snoho and Seattle.
In Win97: File -> Web Import -> RadioReference.com -> Trunked/Conventional
My other question is technical, and it's this: I'm using an ancient PC for my radios, because it has the old style 9 pin hook up. I have a DIFFERENT computer I get on the net (i.e. RR) with. Is there a way to D/L info from RR, burn to CD and then transfer to my PC and upload with ARC or Win software?
Within the dialog box accessed via the above menu selection, you can export the XML retrieved from RR (e.g. one entire trunking system) to a file on disk, then import that XML file into Win97 on another machine.
Win97 also supports USB-Serial adapters, including the "newer" GRE/RS "USB Scanner Programming Cable", on any COM port - so you don't necessarily need a PC with a 9-pin serial port built-in.
