| Scanner Programming Software This is the place to discuss scanner programming and control software. |
08-04-2008, 11:02 AM
How do I import files to my scanner?
I searched and searched and couldn't find the answer, so sorry in advance if it's posted somewhere.
How do I import db files to my software online? I have a prem. membership, but don't know how to do it. I'm sure someone has the link to the wiki or something.
Thanks,
Eric.
NREMT-I
Pro-97
BCD996T
Cheyenne, WY
08-04-2008, 11:04 AM
Wiki Admin
What software are you using? ARC996, BCTool, FreeScan and ProScan(for the 996) and Win97 (for the Pro-97) all have the ability to import data from the database. Connecting to the database is usually nestled inside a pulldown. You will need your RadioReference userid and password
73 Mike
[edit] Don answered that very question in the thread below for Win97...
http://www.radioreference.com/forums...d.php?t=114471
08-04-2008, 01:27 PM
73 Mike
I am using the UASD software from the uniden website.
NREMT-I
Pro-97
BCD996T
Cheyenne, WY
08-04-2008, 01:31 PM
The UASD doesn't have the direct download ability like the other mentioned software does.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
08-04-2008, 02:03 PM
Wiki Admin
However if you have Excel or similar, you can use the procedures outlined below;
http://wiki.radioreference.com/index...al_to_Software
If you don't, both FreeScan and BCTool support the 996, have the RRDB import ability and are freeware. The links can be found in the PC Programming section of:
http://wiki.radioreference.com/index.php/BCD996T
73 Mike
08-04-2008, 09:03 PM
Forums Manager
Wrong forum. Moved to Scanning Software.
08-04-2008, 11:07 PM
What software do you reccommend?
NREMT-I
Pro-97
BCD996T
Cheyenne, WY
08-05-2008, 05:25 AM
Wiki Admin
I don't have a 996 - yet. However I have a couple of other much older scanners plus the 396 (the 996's cousin) and am relatively pleased with Scan Control This package doesn't have the RRDB import function (to me, that was a huge mistake) - I would go for either of the freeware packages. You won't lose anything (i.e. cash) by trying them.
A side note - most new PCs these days don't have serial ports. You will need a USB-serial converter. Uniden sells them (their model is USB-1), and several other manufacturers also have them that seem to work fairly well. Be sure, once you buy one, to go to the manufacturer's website to download the latest drivers. That, as well as assigning a COM port that's open, are the 2 biggest hangups when using these converters.
73 Mike
08-05-2008, 10:59 AM
I would try the 2 free programs mentioned above BCTool http://www.bctool.org/ and FreeScan http://www.scannow.org/ both seem to work well, I think BCTool is a bit more intuitive to use.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
