Old 08-04-2008, 03:13 PM
Send a message via AIM to jngizzi
Default Butel Software Profiles: 396 to 996 Conversion?
I just made extensive changes to my Uniden 396 using the Butel software. Is it possible to somehow export the profile from the Butel 396T software and import into the 996T software so that I can subsequently load the scanner with this profile? This will save me the time of re-creating the changes in my 996T version of the software.
I understrand that both radios use different file configurations.
Thanks,
Joe
____________________________________________
My Toys;
AOR-8200
RS-2006
996T
396T
OptoElectronics Video Sweeper
1992 Corvette LT1
2008 Corvette Z06
Old 08-04-2008, 03:54 PM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
In ARC996 select File _ Open System and change file type to ARC396 Data Files.
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Become a BuTel Software affiliate! Check our website for details.
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 08-10-2008, 06:17 PM
Gommert
Gommert,
I'm in the ARC396 where I initially established my systems and profiles. Now, when I try to "save as" the 996T format in the "save as file type" is not listed as an option. This is when I try to do a "save as" for systems and profiles.
I do have the ARC996 and ARC396 pro versions loaded on my PC. I'm not sure if I need to do anything special to get the "save as type" entries to appear in the drop down box.
Thanks in advance for your help.
Joe
My Toys;
AOR-8200
RS-2006
996T
396T
1992 Corvette LT1
2008 Corvette Z06
Old 08-10-2008, 06:50 PM
captclint's Avatar
You need to read his note again. You do this from the 996T menu.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 08-10-2008, 07:48 PM
ok. Maybe I'm not reading the above correct. Keep in mind my source profile and systems are created in the 396T software.
If I understand you know I should;
1. Start the 996T software
2. Open the profile/systems that I created with the 396T (source systems)
3. Do a Save As in the 996T format
4. Download to 996T Scanner
Did I get it straight this time? Thanks for your help and patience.
Regards,
Joe
My Toys;
AOR-8200
RS-2006
996T
396T
1992 Corvette LT1
2008 Corvette Z06
Old 08-10-2008, 09:06 PM
captclint's Avatar
Yes, you keep your 396 files alone. I don't have ARC996, but you really have nothing to lose by trying exactly what Gommert said. Just File _ Open, System and change file type to ARC396 Data Files, and it should load those into ARC996, and then you can download to 996T. If not, come back and ask for more clarification.
Regards,
Clint Chamberlin
Luzerne County, PA
Similar Threads
BuTel releases FIRST and FREE software for Bc246T Butelsoftware Uniden Scanners 10 05-02-2009 01:22 PM
Butel software problem? gas Scanner Programming Software 0 11-09-2007 11:48 PM
software for my 396t jlo Uniden Scanners 3 10-22-2007 02:44 PM
Migrating 396 files to 996 firemedic2150 Scanner Programming Software 6 10-15-2007 05:59 PM
New 996 & 396 Software billfx Scanner Programming Software 1 03-09-2007 12:46 PM
