Old 08-04-2008, 05:04 PM
mipsyop's Avatar
Send a message via Yahoo to mipsyop
Exclamation win96 question
What the heck!!!!! I can't communicate with my scanner with win96. I get "timed out waiting for the header" What does this mean, and how can I fix this? I HATE manually programming this dang thing!
Adam S. Burling
Old 08-04-2008, 05:11 PM
pappy1's Avatar
Check the com port. Use device manager to check the correct setting. or if the option to find it for you is in the drop down menu, use it.
writ by pappy1 all errors are mine except spelling that is the fault of the Local school system.
Old 08-04-2008, 05:20 PM
There are a few potential causes for that message:
1. COM port in Win96 not set correctly (Configuration -> Serial port)
2. Not using a serial cable that works with the PRO-96
3. Scanner not turned on, cable not plugged into PC and/or scanner's PC/IF jack, etc.
I'll keep my freedom, my guns, and my money... you can keep the change
Similar Threads
Manual programming question manross Radio Shack Scanners 2 01-10-2007 10:31 PM
Win96 Extended Frequency Question xusmarine1979 Ohio Radio Discussion Forum 13 08-10-2006 10:39 PM
Win96 Key Question snjct2000 Scanner Programming Software 15 08-07-2006 12:35 PM
Win96 Help! Please Post your Oahu Scanner files or Win96 Screenshots here... Jamrock808 Hawaii Radio Discussion Forum 1 07-18-2006 02:26 PM
Help with Pro-96 & Win96 fyrfyter33 Radio Shack Scanners 27 11-20-2005 01:40 AM
