Originally Posted by bc780l
With me being a beta tester for IDtracker( oh yeah, the GRE 500 and 600 is in public beta on the website ), it will do everything except if you want both separate banks, systems or object all in the same sound file. At home I have a P25 system in one object(or bank) and the county fire which is still conventional in another object and the IDtracker program cannot put all the traffic into one sound file.
The only free program that can do that is scanner recorder. Unless you donate to get a copy of the beta of scanner recorder pro, it will not stop and start recording a new file after so much time. So unless you stop it you would have a wav file hundreds of megs big. Where IDtracker and start a file after soo much time which I set to 25 minutes of audio.
Scanner recorders homepage is
http://www.davee.com/scanrec/
If you only have one bank, system or group you listen to and you have a GRE 500/600 or one of the unidens I would use IDtracker. I have used both and are great free programs. If you don't have one of the scanners that IDtracker can handle, then scanner recorder is the best solution being it is free. Just remember to stop and start a new file everyday.
