  #541 (permalink)
Old 02-12-2011, 8:08 PM
Default menus
i am running the 21 version. i cannot see the file,edit,view,project, operate options on top of the screen , nor can i see the word " two tone detect " it seems like its clipped off . any ideas?
pete
  #542 (permalink)
Old 02-17-2011, 9:45 PM
Default Two Tone Detect
I'm not sure what I'm doing wrong I have downloaded the software with all of the other necessary links, setup all of the necessary information and I still can not get the email to send. I feel like I'm doing the email setup wrong. My personel email is gmail however I just go on-line to check email, I don't have a gmail downloaded to my desktop. I checked everywhere for step by step instructions incase I'm doing something else wrong....Any help would be greatly appreciated. I am running Windows Vista
  #543 (permalink)
Old 02-23-2011, 5:33 PM
ttnb0811
email me and i can help
tjacks3441@gmail.com
  #544 (permalink)
Old 02-27-2011, 8:36 PM
Default AT&T Fix
Did anyone ever figure out how to get this to work on AT&T's network?
  #545 (permalink)
Old 03-14-2011, 12:46 PM
iamhere300's Avatar
So I have all these MMS addresses in the program, probably 40 or 50. What file is the program saving this to, so I can back it up? Possibly so I can edit it directly?
  #546 (permalink)
Old 03-20-2011, 5:29 PM
it is saves it to the tone definition file. should be a txt file under your c drive called tones, you can also edit the information there and it will save in the program, it makes it a little easier
  #547 (permalink)
Old 03-28-2011, 7:01 AM
Kingmobileaudio's Avatar
Send a message via AIM to Kingmobileaudio Send a message via MSN to Kingmobileaudio Send a message via Yahoo to Kingmobileaudio Send a message via Skype™ to Kingmobileaudio
okay i'm testing this out and every time i send a page it gets it and says waiting for a min or 2 then goes and rec, i get an email but no audio?
win7 64bit
(402) 937-8578
  #548 (permalink)
Old 03-28-2011, 9:10 AM
win7 64bit
well i got it to rec had to lower the "audio threshold"
and says rec but no audio in email?
(402) 937-8578
  #549 (permalink)
Old 03-29-2011, 7:55 PM
kingmobileaudio
check page 25 post 493
if you still have problems email me at tjacks3441@gmail.com
  #550 (permalink)
Old 03-30-2011, 1:02 AM
FIX: the app "Lame" has to be in the Data Folder, someone posted back a few that it's "lame_enc.dll" that has to be in there and that was wrong.
I get audio everytime now in my emails, Thanks for the Program!
(402) 937-8578
  #551 (permalink)
Old 03-30-2011, 11:24 AM
Forts's Avatar
Mentor
Send a message via ICQ to Forts
Has anyone used the "Don't send email between these times option"? Our department does a test page every day at noon, so I entered 11:55 to 12:05 but it doesn't seem to work... emails still get sent out. Suggestions?
  #552 (permalink)
Old 03-30-2011, 4:27 PM
Did you put the email addresses you don't want the test page sent to in the "exclude emails" field? If not, it will still send to them. This allows you to send the test pages to some email addresses but not others. For example, I have it send the test to my gmail account every day so I know the system is working but not to my phone since I pay for every MMS message.
Andy
  #553 (permalink)
Old 03-30-2011, 4:35 PM
Forts's Avatar
Mentor
Yes I did enter the address. I have one long tone setup to go to 2 different addresses, which works fine. However I'm trying to suppress the noon page from going to the second address. Doesn't seem to be working though.
  #554 (permalink)
Old 03-30-2011, 7:02 PM
wizard of odd
I'm running this on a semi-dedicated computer (only has scannercast and this). About once a week the system will totally lock up and require a reboot.
I run it on a Pentium 4 HT @ 3.4GHz, 1 GB ram, and fresh install of XP pro. And like I said, the computer doesn't get used for anything else.
Any ideas? I'd like to find a way to make it more stable. I had the same results using a different machine with similar specs.
  #555 (permalink)
Old 04-06-2011, 3:55 PM
Program crashes:
What kind of computer are people using out here. Let everybody know, if it is working good or crashing everyday.
I have two computers running this they are both similar dell 2.6 ghz 1gb ram one works great the other its pretty much every other day it pops an error, the one that pops an error i use more, or i should say it gets more calls throught it.
So the question is do people think it is a memory problem or software?? I guess i want to see if people are having good luck with more memory
  #556 (permalink)
Old 05-17-2011, 11:56 AM
Originally Posted by tjacks34 View Post
Program crashes:
Locks up the program only every few days.
Win 7 Premium, 2 GB RAM, Pentium 4 - 3.0 GHz
I was thinking of running it as a automatic service and either rebooting or have the service auto restart on crashing. Still does not help the crashing problem though.
  #557 (permalink)
Old 05-22-2011, 8:26 PM
wizard of odd
I looked at my RR feed logs, since scannercast goes down too when the program locks up the computer, and it looks like it goes down fairly consistently every 4 days.
  #558 (permalink)
Old 05-22-2011, 8:29 PM
wizard of odd
I have mine set to automatically run when it boots, makes it easier. Just cycle the power and walk away.
How do you schedule a reboot? I've tried with no luck.
  #559 (permalink)
Old 05-22-2011, 10:05 PM
I have had mine running for weeks. I got a Brand new Dell 17" XPS Laptop
(402) 937-8578
  #560 (permalink)
Old 05-30-2011, 9:05 PM
Originally Posted by KF5DCI View Post
This program is awesome. Now I just need to find a way to take the file and automatically transcribe it to txt and email it.
You might be able to do that by email it to an address at Visual Voicemail For Your Phone | YouMail ? I know that you can setup other voice mail systems to feed in through an email address to this service. Might be something to check out.
