Old 09-29-2008, 05:53 PM
Default Using bctool with BCD996T
I've got bctool loaded onto my computer. I've connected the scanner to the computer and everything goes fine until a certain point. I don't have the premium subscription with radioreference; maybe I should. With the setup I have, am I able to cut and paste data from the web site to bctool or somehow import data to bctool?
Also, does the scanner have to be connected to the computer and turned on in order to input data manually into bctool?
Thanks for any help.........
Old 09-30-2008, 12:57 PM
Wiki Admin
If you are trying to import data from the database, you must get the premium subscription.
If memory serves (I have BCTool installed on my machine at home, can't do it on the work PC), it will also import UASD files and others as well.
73 Mike
Similar Threads
Help with BCD996t importing from bcTool cratliff Scanner Programming Software 6 06-07-2008 09:25 PM
New BCD996T with newbie issues? walterb Uniden Scanners 5 05-22-2008 04:45 PM
BCD996T Programming Help Dosster Uniden Scanners 4 05-07-2008 06:19 AM
restoring a bcd996t nmize Uniden Scanners 2 09-05-2007 11:27 PM
Official BCD996T Prerelease Thread UPMan Uniden Scanners 739 05-26-2006 01:21 PM
