Old 11-25-2008, 01:27 PM
Default uniden 785 recordings...
hi all...
ive basically hooked my uniden 785xlt up to my computer from the headphone to the mic socket and recorded transmissions that way, now they sound pretty awful ive attached a file just to prove this, i wasnt expecting this to work first time and it obviously hasnt, has anyone got any suggustions on how to improve on what i have,
thnks in advance
dan h
File Type: zip 11-25-08 16-43-00 - VOX TO 16-43-07.zip (86.6 KB, 3 views)
Old 11-25-2008, 10:17 PM
ProScan's Avatar
I see from the filename that the recording was made with ProScan. Since I make ProScan, I'll offer my 2 cents worth. The recording is saturated due to the audio into the sound card hot (strong).
You're using the "Mic" Input. If you have a "Line" input then use that otherwise if you only have a "Mic" input then attenuation is needed. Check the sound card options for an attenuation setting or a setting that changes the input from mic to line levels.
If there is not a setting then you have a few options as follows:
1) Buy a line level to mic level attenuator.
2) Build a 20 db attenuator pad made from two resistors. The resistors can be soldered in the audio cable using heat shrink and electrical tape. There are diagrams and resistor values online for attenuators pads. Use the unbalanced attenuator type.
3) For testing recording quality - turn down the volume of the scanner but then the scanner volume will be low.
Bob
Taking Computer Aided Scanning to the next level!
http://www.proscan.org ProScan Web Server http://proscan.dyndns.org:443/
bob@proscan.org
Similar Threads
Uniden 'Service'!!!! jwcooper141 Uniden Scanners 7 06-27-2008 06:59 PM
uniden 785XLT vs 785D???Anyone who can tell the difference? etronic Uniden Scanners 5 02-10-2007 07:50 PM
Reputable Dealer Junior08 General Scanning Forum 20 12-14-2006 03:17 PM
Like new Uniden Scanners Uniden sells on line question? johnny_dx Uniden Scanners 5 07-25-2006 04:28 PM
Determining The Fair Market Value of Uniden Bearcat BC796D JASII Old Classifieds Archives 2 06-04-2006 11:04 PM
