Originally Posted by ka3jjz
There's not enough information here to make a determination. Did you zip (compress) the files and not tell the intended receiver? What kind of files did you attempt to send? Did the recipient try to use the explorer uncompress function to extract the file? (it's been known to happen that doing so can corrupt the file. Far better to use an external program such as WinZip). What message in Win500 giving? When is it occurring - when it tries to open, or load the file?
More information needed 73 Mike
Besides what Mike mentioned, it may not be entirely the way you're sending the file at all. It could also be the way your recipients' email program(s) handle attachment. AOL & Outlook (depending on the security setting) may block saving attachments, or change what's saved from it's original format.
And, yes, more information needed, what error code shows up, also what's the file size of what they 'save' versus the size of the attachment you sent.
