Old 12-02-2008, 08:02 AM
Question Trouble downloading with WIN500
I just purchased a RS -106 and having trouble programing,Downloaded win-500 software and don,t understand . My 1st time, having trouble. I'm in the New Iberia La. area.P-25 digital LATIE.
Old 12-04-2008, 11:19 AM
fmon's Avatar
Welcome to the forum. I hope Larry's problem is solved. You've 'hijacked his thread if his problem is not resolved.
However, being your first post, we can try to help you also.
In Win500, click the Tab TSYS Objects. The database indicates Project 25 as type system so:
1. right click in dark gray area and select insert item.
2. click in (default) Mot 800/900 under Type column and select P25 Auto as type.
3. in upper right, click System Frequencies button.
4. from database page, select nearby towers and type in red and blue frequencies then click OK button at top right of frequency dialog.
5. at top, click Edit menu and select new item at end (this places a Talkgroup Object called Wildcard) and is defaulted to Scanlist 1.
You can save the file at this time (File>Save and give it a name). Then send the file to your scanner and start scanning.
Or
at step 5, replace the word Wildcard by clicking into and replace wildcard with a dec ID number found in the database. If you do this, you can add a second ID by righ click on the first Talkkgroup Object line and reselecting New Item at End. (this process can be repeted until all desired Talkgroup objects are programmed.
Frank
RR Wiki Programming Shortcuts
Similar Threads
Win500 Remote Monitoring Setup Questions K8PBX Scanner Programming Software 9 12-29-2008 09:42 PM
Anyone Have Win500 Files for Baltimore Metro Area ? pratzert Maryland Radio Discussion Forum 2 11-03-2008 11:04 AM
Downloading to win500 camelcacher Utah Radio Discussion Forum 6 10-29-2008 11:59 PM
PSR500 and WIN500 Nautical Arkansas Radio Discussion Forum 3 08-17-2008 11:15 PM
Win500 Data Corruption - could kill trunking DonS GRE Scanners 11 11-15-2007 11:09 PM
