Old 12-16-2008, 09:31 AM
Unhappy Butel 996 Software ARCPRO
Paid $$$$ for this software (Newbie, Didnt know any better). Anyway, Is there a way to retain the "Complete" system pkg without having to go and find every conv system everytime I want to reload the radio. Example: I have different counties I have in a list on the left of the display. Every time I try to update or reload to radio, I have to go find all counties I had, individually. This program does NOT retain the list as other programs....Am I missing something or is this correct??
Donny
Old 12-16-2008, 10:06 AM
Should be a save option in the program that lets you save your config to the hard drive??
Old 12-16-2008, 10:26 AM
MikeOxlong's Avatar
Send a message via AIM to MikeOxlong Send a message via MSN to MikeOxlong Send a message via Skype™ to MikeOxlong
Yes, you have missed something. The program does retain the list when you tell it to.
Once you've got all your systems in the lefthand side of the display, save a profile.
Then, when you restart the program, you can reload the profile which will load all your systems back in, or go to the Options and check the box which tells the program to automatically load the profile in when the program is started.
Mike.
Old 12-16-2008, 12:41 PM
Thanks Mike
I knew it must be something I was missing..
Donny
Similar Threads
Butel - 996 & RR Database fuzzymoto Scanner Programming Software 11 09-05-2008 02:06 PM
Butel Software Profiles: 396 to 996 Conversion? jngizzi Scanner Programming Software 5 08-10-2008 09:06 PM
Butel software problem? gas Scanner Programming Software 0 11-09-2007 11:48 PM
software for my 396t jlo Uniden Scanners 3 10-22-2007 02:44 PM
Butel Software still in buisness? USScanner Scanner Programming Software 11 06-21-2006 11:22 PM
