Old 12-18-2008, 01:41 PM
baybum's Avatar
Default Pro-106 cable
Apologies in advance, but I cannot find a definitive answer.
Will the serial cable I use for my Pro-96 work on the Pro-106?
Many thanks,
baybum
Old 12-18-2008, 01:49 PM
Many thanks,
No.
I just went thru this myself.
You need the USB cable.
Old 12-18-2008, 02:03 PM
baybum's Avatar
Not even for programming....dang!
Thanks.
baybum
Old 12-18-2008, 02:13 PM
Thanks.
I probably should clarify. I use Win96 and Pro96com for my Pro-96. Serial cable is fine.
I bought Win500 for my 106. It would not work with the serial cable. Had to get the USB.
If you are using different software you might get different results.
Old 02-15-2009, 01:23 AM
Location: Nashville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud
I am using my serial cable that came with my Pro 96 on my Pro 106 in Pro96Com with no problems. I had not tried IDtrackerII. I don't see an option in Win500 to use a serial cable only USB.
PSR-500 | Pro-96 | BCD996T | PSR-600
Webmaster http://westmichiganscan.com
ID Tracker Website
Similar Threads
Rs Pro 106 kerrystarr2000 Utah Radio Discussion Forum 12 12-20-2008 11:32 PM
Pro 106 File For N. Colo (ft. Collins) dougw65 Colorado Radio Discussion Forum 3 12-05-2008 01:03 PM
Pro 106 Cable GFerg1919 Radio Shack Scanners 8 11-03-2008 12:11 PM
Pro 97 Programming Cable 20-047 WisconsinRailfan Old Classifieds Archives 4 01-29-2008 08:40 AM
RS Pro 2051 to PC cable cnmsales Radio Shack Scanners 3 09-06-2006 12:50 PM
