Old 12-20-2008, 04:49 PM
John_M's Avatar
Default Can't get Win500 to open:
File won't open.
John.
Old 12-20-2008, 05:04 PM
pappy1's Avatar
Download a new copyt from starrsoft and copy the .EXE file on top of the old file. worked for me.
writ by pappy1 all errors are mine except spelling that is the fault of the Local school system.
Old 12-20-2008, 05:12 PM
John_M's Avatar
Didn't work Pappy. I'm using Vista 64bit if that makes any difference. I installed the files into the 32bit section.
John.
Old 12-20-2008, 05:54 PM
KT4HX's Avatar
Send a message via Yahoo to KT4HX
Since you didn't mention it, I will ask. Did you check the Starrsoft page for Win500 for any guidance on Vista, or contact Don directly with your query? I would start there.
http://www.starrsoft.com/software/win500/default.asp
Alan
Scanners: PSR-600 | PRO-106 | BCT-15
Old 12-20-2008, 06:03 PM
pappy1's Avatar
Did you make a new folder in the 32 bit and useing winzip extract the files there and from that folder open winXX.exe. do not try to install them.
Old 12-20-2008, 08:21 PM
There are no Vista issues. Unzip the files, run it. Nothing more, nothing less...
Old 12-20-2008, 08:31 PM
John_M's Avatar
I did that Pappy. I went ahead and bought ARC500. Now I can't get the software to program my information into main memory. Not sure which steps to take to get the radio to accept the information. It says it did but nothing in scanner. I believe I am in one of the V-Scanner folders.
John.
Old 12-20-2008, 08:57 PM
pappy1's Avatar
I just put it on my daughters Vista64 and it opened and ran just fine. It must be how you have your computer configeated that is stopping it from opening. Your virus software could be blocking it.
Edit: I am useing Win500 program.
Old 12-20-2008, 10:17 PM
John_M's Avatar
The cable I am using needed a USB to Com port driver. The software is working now. Thanks.
John.
Similar Threads
UT and open mic Liverdog Trunking Control Channel Decoding 1 11-17-2007 04:59 PM
More on Open Sky: Blair Co brey1234 Pennsylvania Radio Discussion Forum 1 11-04-2007 06:44 PM
Open House Montgomery County & DC ScanManQSL Maryland Radio Discussion Forum 0 10-14-2007 11:28 PM
Ny/pa And Open Sky brey1234 New York Radio Discussion Forum 18 08-22-2007 12:45 PM
Pa/ny And Open Sky brey1234 Pennsylvania Radio Discussion Forum 5 08-16-2007 05:50 PM
