It would help if you said which software you are using. Did you perhaps add an alert tone to some channels? I use that quite frequently to alert me when a little-used channel is being used. That might be the source of the 'beep'. Dump your programming and attach it as a zip file so others can look at it, and perhaps make a diagnosis.
Note also that you can't put a delay on each channel. That's one of the shortcomings of this DMA stuff. If you want certain channels to have a delay, I think you would need to set up a new system so the delay applies system-wide. 73 Mike
