Old 12-27-2008, 07:05 PM
supernoma's Avatar
Send a message via MSN to supernoma
Default MDT Decoding
In regards to the MDT system I've found and asked about here: http://www.radioreference.com/forums...d.php?t=129133
I don't know what type of system that it is.
So has anybody sucessfully decoded MDT signals? I found a program that is called "Taxi MDT Decoder" http://sourceforge.net/projects/taxidecoder but cannot make heads or tails as to how to use it.
Anybody done this?
PRO-83
PRO-508
PRO-2030
PRO-2044
BC860XLT
BCT7
BCT15 x2
BCD396T
...Trust Me!
Old 12-27-2008, 09:15 PM
Yes. That program would have to rate as the most poorly documented program in the history of computing.
From reading some of the files, it requires SoundCard input. And as it is based on Tronquito, you might get away with Speaker audio, and not require a Discriminator Tap.
And it appears that it requires Java Swing, whatever that is.
Comint
Similar Threads
MDT decoding slidder General Scanning Forum 10 03-13-2009 06:57 AM
How Do I Monitor MDT Systems? Bluegrass1dcr1 General Scanning Forum 13 04-02-2008 02:56 PM
GRE Representatives addressing P25 decoding issue? cellphone GRE Scanners 12 10-29-2007 04:52 AM
Help with rtty and fax decoding on HF Saint HF/MW/LW General Discussion 22 01-11-2005 07:48 PM
SCA/RDS Hardware and Software Decoding crayon Tavern Archives 1 06-10-2004 08:56 PM
