Old 12-28-2008, 10:01 AM
rja1's Avatar
Default Help with ARC96
Just picked up a PRO96(on sale, $199) & programming cable. Trying to load NYS Electric & Gas. They have a new TRS, VHF Motorola P25. Software is asking for frequency, offset & step. The stickey on the NY forum page has lots of info, but not the above mentioned items. It has sys ID, WACN & NAC. I would like to load just the CC's & let 'er rip in open mode. Any help with this would be greatly appreciated.
Thanks,
bob
n2oam
Old 12-28-2008, 10:39 AM
is this it?? http://www.radioreference.com/apps/db/?sid=6033. you probably need to ask in the NY Forum.Also program ea frequency in FM Mode
Old 12-28-2008, 11:03 AM
fmon's Avatar
Thanks,
bob
n2oam
Get Mike's outstanding and free Pro96Com program http://www.psredit.com/#Pro96Com. Enter any site active control in scanner as MOT:. Then set scanner on that control as per Pro96Com instructions. Run program for a few seconds then open the Tower txt which it generates (similar to attached tower 0111.txt file. A Table listing will be in file with Base Freq, Offset and Spacing (step).
Frank
RR Wiki Programming Shortcuts
Similar Threads
ARC96 - Problem with mutiple site systems ATCTech Scanner Programming Software 10 11-16-2008 01:18 PM
ARC96 / Fleetnet etc. ATCTech Eastern Canada Radio Discussion Forum 1 10-29-2008 10:43 AM
ARC96 extended frequencies soupbones Scanner Programming Software 0 10-12-2008 01:04 AM
Arc96 and Pro-96 Display 2redline Scanner Programming Software 9 10-09-2008 07:14 PM
win96 vs arc96 K3RBP Scanner Programming Software 1 08-25-2008 05:04 PM
