Old 12-28-2008, 10:23 AM
Default UASD hides files?
I am trying to copy a system file (*.usd) I have programmed in the UASD software. I am attempting the copy through Windows Explorer, onto a jump-drive. The entire system configuration and data is 'there' when I view it through the UASD program. However, when I look for the file through Windows Explorer it is not present. Yes, I have confirmed the location of the files through the setup menu in the system editor. Note: this happened after I duplicated (copied) a system configuration through the UASD copy function, and then subsequently edited the system and saved under a new system name.
What am I missing? Anyone know why the file is not present in Windows Explorer?
Jake
Old 12-28-2008, 02:21 PM
go to controll panel
folder options
enable show hidden files
thats where it is in vista
Old 12-28-2008, 02:48 PM
Jay911's Avatar
Send a message via ICQ to Jay911 Send a message via AIM to Jay911 Send a message via MSN to Jay911 Send a message via Yahoo to Jay911
.USD files don't count as 'hidden and system files', or shouldn't.
I don't use UASD enough to remember, but is it possible you're looking at a different folder? I myself have had that issue specifically with things that are placed in the My Documents folder, because some installations save in C:\Documents and Settings\Default User\My Documents\{etc}, while others save in C:\Documents and Settings\Jay911\My Documents\{etc}, and so on.
--j.
VE6SRT
Old 12-28-2008, 02:52 PM
Unhappy
folder options
Thanks, but no success there. Windows Explorer reveals the original files I created in UASD. I think the key is in the fact that this happened after I copied an existing system and then modified and named the system differently. The real kicker is that the newly created system file can be opened and edited in UASD. The UASD options shows me where the system file is located on the computer (I've verified this repeatedly). BUT I CAN'T FIND IT OUTSIDE OF UASD!!!! Frustrating!
Jake
Old 12-28-2008, 02:57 PM
Unhappy
By the way...all of the system files missing from Windows Explorer happen to be trunked systems. The files I can 'see' are all conventional systems. Weird!?!?
Jake
Old 12-28-2008, 03:07 PM
Jay911's Avatar
Try searching from Explorer (using Search Companion, if you have that Live Search atrocity invading your PC) for all *.USD with a starting directory of C:\ and see if the machine can find it.
--j.
VE6SRT
Old 12-28-2008, 03:11 PM
Yeah...tried that also. That is when I really got confused! The only .usd files that the search function finds are the files I can locate.
Jake
Old 12-29-2008, 10:26 AM
DaveNF2G's Avatar
Explorer treats your own documents as two separate "places" on your hard drive, even though they only exist once. Also, Windows installers sometimes create "ghost" directories for data files for certain programs under My Documents. When the software itself offers the option of choosing storage directories, there can be as many as three different places in on your hard drive (displayed as four different places in Windows Explorer) where such files might reside.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 12-29-2008, 12:18 PM
UPMan's Avatar
Uniden Product Manager
Maybe the name is not what you expect it to be. Try this: Make a slight change to one of the mystery systems and save it. Then go to the directory pointed to by UASD setup and sort that directory by date. The system you changed should be the one with the most recent edit time stamp.
Got a question? Ask it in a public forum for faster response.
My solar power station
Old 12-29-2008, 12:24 PM
unitcharlie's Avatar
Kentucky DB Admin...
I found mine here... this was in addtition to all the other places Uniden hides files.... complete profiles, etc...
C:\Users\{YOUR USER NAME}\Documents\UASD_DataBase\BCD396T\UASD_systems
good luck.... I always plug in my jump drive and copy the final version of everything to it so I can find them more easily....
Co-Founder/Active Member of the Central Kentucky Monitoring Team
Opinions based on MY experiences, real AND delusional...
WX4LEX
unitcharlie@radioreference.com
Twitter: CollierLEX18
Old 12-30-2008, 09:52 AM
Default Found Them!
Unitcharlie wins the prize. You didn't have the exact correct answer, but yours was the closest. I finally found the files, but am still a bit confused. I think it may have something to do with the Windows Vista Home Premium on an hp computerand probably nothing to do with UASD.
This is the path in which UASD was telling me the system files were stored:
C:\Program Files\Uniden\Software\Databases\BCT15\Systems
This is where I actually found them:
C:\Users\{Name}\AppData\Local\VirtualStore\Program Files\Uniden\Software\Databases\BCT15\Systems
I don't now where the virtualstore route came into play. Again, the first path was described in the UASD setup options by me. How it diverted the new files to the new location is perplexing. But, I am easily perplexed. Thanks for everyone's input.
Jake
Old 12-30-2008, 09:55 AM
My apologies DaveNF2G...your answer was perhaps just as accurate (or more so). thanks.
Jake
Old 12-30-2008, 12:27 PM
I was told, when I asked the same question on one of the forums, it has to do with automatic file extraction. I was complaining that one of the programs, butel's I believe, loading down my computer with all these files, many of which were not complete mirrors of the load in the scanner. These files had accumulated to the point that my XP computer turned into oatmeal until I cleaned it out. I have since found that running the programs (I use ARC396PRO and sometimes bcTool) from a jump drive and turning off the scanner saves a lot of space, heartache and time.....
WX4LEX
Old 01-12-2009, 07:15 PM
Send a message via AIM to ddanz Send a message via Yahoo to ddanz
Lightbulb Lost .usd files - an explanation
This is a Vista-ism; do not attempt to store data files in the Program Files directory (for security reasons, programs shouldn't be able to write to anything in the Program Files directory, it's for PROGRAMS.
Yeah, yeah, I know - plenty of lazy programmers setup their programs to do it, but Vista will disallow it.
Put your UASD file in your c:\Users\{Name}\Documents\ directory.
Dan Danz
Fountain Hills AZ
WA5SKM
Similar Threads
New StarCom21 Files for ARC and UASD 996 N9JIG Illinois Radio Discussion Forum 0 03-09-2008 08:06 PM
UASD files, please! plaws Oklahoma Radio Discussion Forum 9 07-14-2006 08:00 AM
Official BCD996T Prerelease Thread UPMan Uniden Scanners 739 05-26-2006 01:21 PM
UASD uploading files to yahoo group help?? ?? ?? ?? safetyobc Scanner Programming Software 5 07-04-2005 01:38 PM
BC246T UASD DEMO FILES Voyager Uniden Scanners 0 01-22-2005 04:51 PM
