Old 01-03-2009, 12:25 AM
slypx's Avatar
Quebec DB Adm
Question ARC396Pro and 996 vs wrong conventional alpha-tag import
Hi everyone, sorry if the question has already been asked but I've search and couldn't find anything ...
Am I missing something in conventional frequencies and importing of their alpha-tags ???
It seems that when I import conventional frequencies from RR DB directly with ARC396Pro and ARC996Pro I don't get the alpha-tags at all.
I only get the "description" field twice, once in the "comments" field and another time in the "name" field instead of the alpha-tag in this last field ??
I've looked at all the software options and don't find a way to correct that.
When I import a trunking system and his TG's, everything is find, I get the "alpha-tag" field imported in the name field where they should be !
As a user AND as a DB Admin, I find this to be annoying and challenging, any idea that would help me solve this ?
Gommert ?
Please folks don't tell me to change software, I have the others (Proscan, BC tool, etc.) but just want these Butel software to do correctly want they should do !!
Slypx
Quebec DB Admin
BCD996T (2) | BCD396T | RH96 | BC780XLT | BC895XLT | PRO60 | PRO2006 | Winradio W1500E | Icom R2500 | PSR600 | BCD396XT ...
Old 01-03-2009, 05:35 PM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
ARc396/996 only imports the description field, until recently many alpha tags were missing in the database. With the new alpha tags I will change this in the next release of the software so you can select alpha tag or description.
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Become a BuTel Software affiliate! Check our website for details.
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 01-04-2009, 11:46 PM
slypx's Avatar
Quebec DB Adm
Thanks Gommert for a quick reply.
I know you are working hard on ARC500 right now, but there is lot of us using ARC396 and/or ARC996 and the question was asked before but is there any time frame on delivering these new releases with that feature and a (long due) V3 of ARC996 to match V3 of Uniden and a new release for ARC396 ?
Slypx
Quebec DB Admin
