You haven't deleted anything important at all - the preprogrammed frequencies you erased are in an user-controlled area in memory. They are still there, just in a protected area of memory. You should clear out the user area anyway, since it frees up available memory for whatever you wish to program.
For questions about importing into FreeScan and uploading, please see the user manual, which is hosted in our wiki. Here is the link...
http://wiki.radioreference.com/index...can_User_Guide
When you are at the upload programming screen, make sure you put a check mark next to the system(s) you wish to upload.
What is 'the Trunker'?
73 Mike
[edit] By the way, the author is available on the FreeScan forums - which is on the same site as you downloaded the program. That's often the fastest way to get answers about his software.
links editor,
Utility Monitoring Central
