Old 02-04-2009, 05:57 PM
CVPI4Ever's Avatar
Default arc780 Chear Sheet needed
Ok, I downloaded a demo of the arc780 for my Uniden BC780XLT and I want to purchase it but dont quite get it. I want to program frequencies from Franklin County, Ohio in to it
Scanner Frequencies: Franklin County Public Safety Trunking System, Columbus, Ohio
Can anyone tell me what to do, step-by-step? Thanks!
Old 02-04-2009, 06:48 PM
get a programming cable & premium subscription & dl em that way , or just copy & past eM?
Old 02-04-2009, 07:15 PM
CVPI4Ever's Avatar
That doesnt help me. I dont have alot of $ to dump into this.
Can any one tell me step-by-step?
Old 02-04-2009, 07:16 PM
fmon's Avatar
Terminology may be a little different, but a programming shortcut for the 785 can be found under my signature.
Also, as far as using ARC780, a very decent help file should be with the program...at least it's in the download and install I just completed.
I'll stick with you if you need additional help.
Frank
RR Wiki Programming Shortcuts
Old 02-04-2009, 07:57 PM
fmon's Avatar
Download and unzip and load this ARC780 file.
It has bank 1 and 2 with law. 3 and 4 as fire/ems.
Frank
Old 02-04-2009, 08:45 PM
CVPI4Ever's Avatar
fmon, thanks! I tried to download the file and it wont let me have it. What do I open it with?
Old 02-04-2009, 09:11 PM
Worked for me.... use arc780 to load it?
Old 02-05-2009, 04:43 PM
Smile
you will Have to have a programming cable to transfer from the computer or ANY s/w program into the scanner.... & how does copy & paste cost any $$$$???
Old 02-05-2009, 09:09 PM
Wiki Admin
There are a great many freeware unzippers - I use 7zFM which isn't bad, but there are others. Go do a search on CNet or any of the reputable freeware distribution sites....I don't trust the zip extraction in XP Explorer as it has the habit of corrupting files on occasion. 73 Mike
Old 02-06-2009, 09:14 PM
CVPI4Ever's Avatar
Subscriptions cost money
Old 02-07-2009, 10:05 AM
Question
Originally Posted by cvpi4ever View Post
subscriptions Cost Money
Copy & Paste Does Not Cost Anything!!!????
Old 02-07-2009, 10:11 AM
Are you actually reading the replies on here?????.To Load any frequencies from a file (on your computer) OR transfer from ANY Software package . or Web import to ANY SCANNER will REQUIRE A programming cable.
Old 02-07-2009, 10:13 AM
Do you know what cut(copy) and paste is????
Old 02-07-2009, 10:21 AM
fmon's Avatar
CVPI,
Download this text file. Find it, right click and select rename from popup. The file name will be in blue with prompt after the last t in .txt. Back space through the .txt including the (.), leaving FRANKLIN OH.mem
Click ok on warning note. Open ARC780, click on Files and navigate to the file.
Frank
Old 02-08-2009, 04:54 AM
CVPI4Ever's Avatar
Yes, and I already have a programming cable (DB-9).
Old 02-08-2009, 09:35 AM
fmon's Avatar
I figure you've had 19 hours to download and change name of FRANKIN OH.mem.txt to FRANKLIN OH.mem then open that changed file in ARC780 and it to scanner.
BTW, a review of the file indicates bank 4 has the talkgroups but I failed to copy the frequency info to that bank. You can go to bank 3, press ctrl a, ctrl c then click bank 4 and press ctrl v. Save and load to scanner.
Frank
Old 02-08-2009, 12:00 PM
LordJ's Avatar
Send a message via MSN to LordJ
Dude, do yourself a favor and try proscan before you purchase the ARC software....
Just because I can, doesn't mean I will. (But I might)
Old 02-08-2009, 12:18 PM
Dubbin's Avatar
No need for that when ARC is cheaper and will get the job done.
Dwayne
My Scanner Feed
Old 02-08-2009, 09:03 PM
LordJ's Avatar
$20 cheaper and no support, will only work with one radio, no recording.
Direct quote from seller "IMPORTANT: this software is now sold 'as is'. This software will not be updated anymore. Please try the demo BEFORE purchasing a license for this software. ARC780 is written in an older development language and only supports short 8 character filenames!"
Software has been tested with Vista and works but we do not officially support ARC780 and Vista.
$30 would be not well spent, but then again that's just my thought...
Old 02-09-2009, 08:20 AM
CVPI4Ever's Avatar
I noticed that too about the Arc780 software, how it was no longer supported. Where can proscan be had?
Similar Threads
Flash/DSP Matrix Sheet Help Needed! rmiles Harris / MA/COM / GE / Ericsson Forum 0 08-11-2008 08:48 PM
RR Wiki Info & Help Needed from Our Users loumaag General Scanning Forum 4 06-08-2007 08:17 PM
Hams Needed leawoodcops Texas Radio Discussion Forum 0 09-08-2005 12:42 PM
PRO-99 Cheat Sheet Needed LarrySC General Scanning Forum 5 05-23-2005 08:49 PM
ARC780 File for finding UHF LTR channels cg LTR Trunking 7 05-22-2004 07:43 PM
