Old 03-02-2009, 11:24 PM
Default Computer won't find scanner! Help
Win XP to BCT15. Using supplied DB9 serial port cable. Baud rates are the same. Read the Users Manual five times. Uniden is no help. Can anybody tell me how to look in Device Manager to see whats right and/or wrong?
Old 03-04-2009, 12:36 PM
Wiki Admin
On my XP system here at work, it would likely be under 'Ports COM/LPT'
Dumb question - did you configure the ports on the BCT15? I would think you would need to do that first; at least you're not using a USB cable...and what software are you trying to use? 73 Mike
[edit] The instructions for setting the serial ports can be found in the 'settings menu' section of:
http://marksscanners.com/BCT15/bct15.html
Old 03-04-2009, 01:06 PM
Bucko's Avatar
The only thing to set in the BCT15 is the front or rear connections ( for supplied cable make sure it is to the front) and bps rate. In your computer go to Administrative tools then computer management, device manager. Scroll down to com port to see what port is assigned (the communications port is usually com1). What software are you using? The big thing is assigning the correct port in your software...
Old 03-08-2009, 01:57 AM
Default computer still looking for scanner....
software = BCT15UASD (which software would you suggest?) I'm going for com port 1.
Old 03-08-2009, 09:23 PM
I just did that at
http://www.radioreference.com/forums...ial-cable.html
It sure would be easier if you kept this all in one place instead of two threads in this forum and one in another.
Old 03-15-2009, 12:32 AM
I am having the same problem. Running XP, have the serial to USB cable with driver installed. Computer is seeing it. I tried to change the com port setting. No matter which one I try to use, I get "can not open com port, it is being used by another device" Device manager says I have only one com port being used.
Old 03-16-2009, 09:28 PM
wendallb's Avatar
I had to go into the bios setup and change the serial port numbers and then it worked. If you bios is set on automatic for the serial port it will not work with xp.
All the Best
Wendall
kc5ess
kc5ess Blog
Blue Ridge Fire Dept.
Old 03-21-2009, 04:15 PM
Smile got 'em talkin (WinXP and BCT15 scanner)
Thanks guys, I finally got it fixed. I found out from a computer junkie that the 9 pin serial port on the back of the CPU is usually COM Port 1. It is often unused because nobody uses 9 pin serial cables anymore because of the superior (and faster) USB cables' available these days. I had to uninstall the driver that was on COM Port 1. Set the baud rates to 57600. (i guess 115200 was too fast for the DB9 cable). I used the auto detect feature and they finally started conversing.
Similar Threads
Shelby - help me find a scanner that works mrjosh North Carolina Radio Discussion Forum 7 09-05-2007 02:26 PM
Computer Interference Harmful??? policefreak General Scanning Forum 11 07-03-2007 11:29 PM
scanner on computer VECTOR-77 General Scanning Forum 13 01-04-2007 02:20 AM
Computer as scanner program TXjeep98 Scanner Programming Software 1 09-02-2006 09:58 PM
Scanner Audio has hum when hooked up to computer. tspainiv Tennessee Radio Discussion Forum 7 08-20-2005 04:33 PM
