Old 03-03-2009, 11:40 PM
401402's Avatar
Send a message via Yahoo to 401402
Default win 500
on the last page of win 500 importing from radio ref
the line box says, TSYS OBJECT says -1? is that what setting it should be?>>
and the same in the starting TGRP OBJECT ID box is -1
should i leave those numbers the same?
what are they for?
thanks ron
Old 03-04-2009, 08:40 AM
Those are for assigning "Object ID" values to the created TSYS and TGRP objects. If you leave them at the default of "-1", Win500 will choose the object IDs.
The TSYS Object ID field is also used if you're importing only talkgroups into an existing TSYS. Setting that field to the Object ID of an existing TSYS, without selecting any sites or frequencies, will add the selected TGRPs to that TSYS.
Old 03-04-2009, 08:37 PM
401402's Avatar
ok i'm confused i'll email u about your last sentence!!!!!!1tsys object id
Old 03-06-2009, 09:09 PM
401402's Avatar
i dont get it
Similar Threads
Win 500 % Win 500 Remote Server Access btritch Scanner Programming Software 0 07-16-2008 09:00 PM
Ho Do You Record On The PSR 500 Using Win 500 Software... btritch GRE Scanners 3 06-25-2008 10:23 PM
Question About Loading V Folders Into win 500 btritch GRE Scanners 5 06-18-2008 07:59 PM
Win 500 Win 98 NDRADIONUT Scanner Programming Software 3 05-13-2008 08:57 PM
gre 500 and win 500 trouble jonboy11 GRE Scanners 8 02-10-2008 12:27 AM
