Old 03-05-2009, 01:44 PM
Default Interface cable help
I can't get my interface cable to recognize my scanner. I have been running it on com 4, now all I can pick up is com 1 and it will not work on that one. Is there anyone out there that has ran into this? I appreciate any help you could give me.
Thanks,
Shakey
Old 03-05-2009, 02:48 PM
check com ports & see why only 1 is working.. Probably need to diasble some autosync s/w??... just a guess....
Old 03-05-2009, 06:56 PM
gmclam's Avatar
Default COM or USB cable?
Are you using a COM version cable or a USB cable? If you are using a COM version cable, what happened to COM4? If you are using a USB version cable, why can't you set your software to COM1 where the cable currently is?
COM issues can be complex and depend on your system. Older systems used COM ports for mice and internal modems among other things. If you have a serial mouse or modem, those devices could be interfering with a COM version cable.
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
Similar Threads
Serial -vs- USB cable (GRE) aaronp Radio Shack Scanners 3 03-10-2009 11:34 AM
RKI: RS USB cable Cat. No. 20-047 does not work with Win96 in Windows Vista MHZ Radio Shack Scanners 16 09-24-2008 11:22 AM
Serial Cable vs. USB Cable emslt245 Scanner Programming Software 9 06-17-2007 07:49 PM
PC Interface Cables for RadioShack Scanners HabboX Old Classifieds Archives 1 12-31-2006 11:44 PM
What interface cable for Unitrunker n8yid Trunking Control Channel Decoding 4 12-21-2006 08:22 PM
