I'm still testing.
ARC - Works the best for me for RR imports. I used the ARC996 to simulate the software for the BCD396XT as it is multi-site capable. I'm using ARC 396 for the BCD396T.
ProScan - when importing from a multi-site trunk system from RR for a BCD396T, it will not combine multiple sites (you can only select 1). This requires manually setting up the system, or creating separate systems for each site. Not a problem if I get a BCD396XT which is a multi-site scanner.
bcTool - when importing from a multi-site trunk system from RR, it combines the sites. You cannot keep the identity of the original sites.
FreeSCAN - RR imports work fine. For multi-site systems, it creates a combined site plus it keeps the individual sites. However, I cannot download data from my BCD396T. It starts the download but times out. All the other software I trialed works OK for downloading data from the scanner.
