Old 03-08-2009, 03:02 AM
Default How do I get the BCT15 into remote mode?
I have set the port settings. How to I get the BCT15 into remote mode?
Old 03-08-2009, 10:57 AM
I use freescan. From the top menu, Choose scanner, Control scanner. It has an option to auto detect it and set the port speed settings for you. I have it running now and it works's great.
Old 03-08-2009, 01:36 PM
Wiki Admin
Yeah, once you have defined your ports, you can consider the scanner to be 'RMT ready'. It then will look for a connection from software....by the way, FreeScan will be undergoing a huge rewrite (almost done, from the last reports on his forum) to .NET as well as to fix a rebanding issue. Hopefully it will be done in the next week or two 73 Mike
Old 03-21-2009, 04:44 PM
Hey guys, I realize now that this was a dumb question. I found out that 'remote mode' basically means to be controlled by the computer. There is no 'remote mode'. Its just an option on some of the software to control the BCT15 scanner via computer. Education and experience saved another one!
Old 03-21-2009, 06:35 PM
Wiki Admin
Don't think of it as a dumb question - on older Uniden scanners there was an indication on the screen to tell you that you were in remote mode. Unfortunately there isn't such an indication on these newer ones, so it makes it a bit confusing. 73 Mike
Similar Threads
BCT15 turns in to Quick Search Mode by it self? RedPenguin Uniden Scanners 0 12-31-2008 01:57 PM
Any info about Failsoft mode yakko Motorola Forum 6 12-14-2008 04:57 PM
Mazda 3 BCT15 install with remote head. SShuster221 Pictures Of Your Shack/Mobile Setup 17 09-16-2008 01:08 PM
How Remote is Remote WmHPowell Uniden Scanners 2 09-13-2008 12:10 AM
Tones, PL, CSQ, BM, M, RM, DPL, how do i use them and when? cybyte General Scanning Forum 10 12-07-2005 11:38 PM
