Originally Posted by mandlair
Hi,David I got it going by typing this in the command? regsvr32 scrrun.dll.
So it was the Windows Scripting or more specifically the scripting file system objects causing the problem.
How do I get it to follow my old files they come up on the logging bottom of screen but not what is in file?comes up as whats on scanner?I which I never had this problem ....lol was set up the way I wanted it now nothing?just shows whats on scanner I set to the files I wanted but still goes to whats on scanner?
Make sure the "Data Path" in settings is pointing to your old files.
Oh and also new version wont work at all?Thanks in advance Mike
Not sure why that would happen. The latest version was only a minor change. I need some more detail. Do you get any errors?
