Originally Posted by AlbemarleVol
I cant seem to get Win96 to work on windows vista .. keeps crashing even tried to run it under run as windows xp sp2 and admin. still not working right .. any one have any ideas what i could do to fix this issue?
When you say 'crashing', what exactly do you mean? It doesn't launch? It's locks up? It won't communicate with the scanner? What scanner are you using it with? Are you using the USB programming cable, or the older RS232 serial programming cable? What else is running in the background on these computers?
