Originally Posted by rad1oreference
I use Win97 and had a question on the CT/DC column. I understand that it's the tone column and generally it's a number 120.45 for example. What happens if the tone is like D503N? Do I just enter D503N in the space provided?
The scanner will only understand the values listed. The only exception is when "0.0" is entered, the scanner interprets that as 'search' mode.
What do I choose in the Rx Mode? AM/FM/EDACS/CT/DC/LTR?
Tones are not supported in AM mode. EDACS, LTR & MO modes are trunking modes. When FM mode is selected, the scanner will not decode tones. That leaves DC or CT. Note that if you are trying to program an NAC (P25) code, the PRO-97 can not decode it (or decode the audio on such a channel).
For now I have it selected as DC and only entered 351 instead of D351 since I can only put 3 characters.
If the D of D351 means DC, you did the correct thing. If not, it won't work. Can you tell us the agency/channel you are trying to program? A link to it in the DB here would be great.
