Old 03-17-2009, 08:20 PM
StevieD's Avatar
Default Uniden 996t with BcTool
So i used bc tool to download the data base for minnesota to my scanner.Looks like everything went well i assigned a key number to all of the freq sites.Now here is the thing.I only get hits on maybe 3 channels thats it i get nothing in the city i live in.When i first loaded my scanner with just a few TGIDs and a few freq. that i entered manually i got hits where i live.Where did i go wrong.
Fustrated in Minnesota.
Old 03-17-2009, 08:48 PM
Wiki Admin
There's really only 1 way to truly diagnose this, Steve. Zip(compress) your file and attach it - let other folks see what you did.
My money would be on a missing quick key. BCTool is not very intuitive about how it defines them - if memory serves, on the system screen, white means allocated and enabled, green means not defined (I know, that's kinda backwards, but that's the way it works). But that's just a guess - without seeing the file it's hard to diagnose 73 Mike
Old 03-18-2009, 10:01 PM
StevieD's Avatar
Ok i'll try that.
Old 03-19-2009, 07:40 PM
StevieD's Avatar
Ok here is something odd. I have 1 system 25 groups and 1017 channels.Now when i used the bctool to load up the scanner i get 1 system 25 groups and 475 channels.So why is not loading all channels.
Old 03-19-2009, 07:46 PM
w8jjr's Avatar
Send a message via AIM to w8jjr
As Mike says Give us a zip file of the radio file you are using.
Jim
W8JJR
Old 03-19-2009, 09:05 PM
StevieD's Avatar
Ok hoped this worked
Old 03-19-2009, 09:18 PM
DDan's Avatar
It worked Stevie. All we need now is for someone with a 996 to check it out for you. I have a 396 so bcTool hammers it into something different I think. I got 18 groups and 1037 channels. I didn't see anything wrong but I'm looking at something a little different than you had.
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 03-19-2009, 09:23 PM
Wiki Admin
Yeah, a 396 doesn't support multi site system programming, so it's not conclusive. Let's hope someone does have a 996 and can test it - it could easily be some program bug...if so FreeScan is a better programming package in any case, but it should be sent to the BCTool Yahoo group; hopefully this software will get fixed soon, as it's falling behind with all the firmware fixes rather quickly 73 Mike
[edit] I agree with DDan's count, as I have a 396, not a 996. When I attempted to read the file into BCTool, it warned me that it would flatten it - so what I am going to mention here may be an artifact of that flattening and not necessarily an answer to the problem. These are just things that stood out for me...
- You have 18 groups here, but there are only 10 GQKs available(0-9). This means you must 'double up' on a GQK (put another way, one GQK to handle more than 1 group). This is allowed, but it may not be the most efficient way of setting up your groups. This might be a cause of why you are not getting everything loaded. BCtool's use of the 'GQK lock out' is very counter-intuitive, particularly in the use of the colors to indicate what GQKs are actually available.
- According to the database, the ARMER system is multi site. This can be covered by the 996 - however it causes you to change the way you think about programming. You may need to listen on more than one site (depending on which one(s) give you the best coverage), and you will also need to find out whether all talkgroups are echoed across all sites. The Minnesota forum folks would be the best ones to give you this information. We also have a brief article on the subject of multi site programming in our wiki, linked below;
http://wiki.radioreference.com/index...-Site_Trunking
- You indicate that you are using control-channel only, yet you seem to be supplying all the frequencies. Unless the site you are programming doesn't show any red or blue frequencies (in which case, this would be correct, but then you aren't really running in control channel only mode), you only need those freqs colored red/blue. Don't waste memory space unnecessarily.
- This may be an artifact of the flattening, however the file had no SQKs or GQKs allocated.
- I doubt this is a real issue, but are you sure you want every talkgroup recorded?
- I would guess that you are using a USB-serial converter. Don't overlook the possibility that you have old drivers - they can cause all sorts of wierd things to happen. And along the same lines, I am sure I saw some reports on the BCTool yahoo group that some folks had to slow down the port speed because they were getting loading errors. It probably won't solve your issue, but keep it in the back of your mind.
- If no one jumps in here, I would post on the BCTool Yahoo group and see what they say. I would also jump to the Minnesota forum and see if you can get a handle on other sites that can give you better coverage, and whether those other sites would cover other talkgroups. They may also be a source of help with BCTool programming. Wish I could do more....73 Mike
Similar Threads
Where to buy Uniden 996T Doublet Indiana Radio Discussion Forum 18 01-20-2009 12:38 PM
Uniden BC 996T mounting bracket needed W9NES Uniden Scanners 4 12-21-2007 10:21 PM
Uniden 996T - Trunk Tracking Help brendan1218 Uniden Scanners 0 12-11-2007 02:11 PM
Uniden 996t baddlord777 Uniden Scanners 0 04-19-2007 11:24 AM
Uniden 996T Question reefmikey Uniden Scanners 3 06-13-2006 07:07 PM
