Old 03-23-2009, 09:04 PM
DDan's Avatar
Default Updating Freescan ?
I looked at the scannow site and the wiki and couldn't find updating instructions. Should I remove the old app first or just run the new installer? thanks
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 03-23-2009, 09:19 PM
scancapecod's Avatar
ScanNewEngland Webmaster
Send a message via Yahoo to scancapecod
The two can run side by side; no need to remove the older version. That said I did anyway after I installed the new, as Assaf will no longer provide support for it.
Scott - Scan New England Webmaster
Old 03-24-2009, 06:00 AM
Wiki Admin
That's correct - when Assaf issues .8a, he will probably send that out as a 'hotfix'. I would expect that the method of applying it won't change a lot from what's already documented. 73 Mike
Old 03-24-2009, 06:57 PM
According to Assaf, going from 0.8 to 0.8a (which is now available) is best done by uninstalling 0.8 first. Apparently the hotfix method which was used in the past will not be used for updates to versions beginning with 0.8.
Dick
WD9GRI
Milwaukee, WI
Similar Threads
FreeScan help with BCD396XT rbm Uniden Scanners 8 03-24-2009 12:33 AM
Help with FreeScan and Importing Frequencies Sjswing Scanner Programming Software 2 01-11-2009 05:00 PM
HELP: Migrate to FREEScan from BUTEL's ARC lemish Scanner Programming Software 2 09-24-2008 09:00 AM
Freescan or Butel ARC246 Software ? Madhouse Scanner Programming Software 8 08-22-2008 05:48 PM
396T and Freescan greenham Scanner Programming Software 2 01-21-2008 04:24 PM
