Old 03-24-2009, 02:58 PM
DDan's Avatar
Default Freescan questions
I am using Freescan .8 in preparation for a 396XT and I'm having a few issues.
When I import from RR using the "CC only" default option, I get the voice only channels as well. The CC only box is checked in the site setup window.
When I imported the info from my 396T, the trunk frequencies were dropped. I assumed that this was due to the difference in the T and XT. Then I tried a workaround by importing a system and sites from RR, then copying the sites and pasting them in the systems from 396 that were devoid of trunk frequencies. That is when I noticed the above problem.
All of these sites/groups are from the San Diego RCS system.
Scanner Frequencies: San Diego, County of (RCS - Public Safety) Trunking System, Various, California
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 03-24-2009, 03:05 PM
Wiki Admin
Assaf just released .8a...and I see that the system you are trying to program is multi site. The 396 doesn't support multisite, the XT does. Perhaps that is making a difference? Likely as not you would need to import one system at a time with the 396. 73 Mike
Old 03-24-2009, 03:29 PM
cpuerror's Avatar
DDan,
CC Only mode means that control channel only mode is used, all channels still get downloaded. .8A should fix the problem with the trunk frequencies not present on download. Hope that helps.
http://scannow.org - Download FreeSCAN
Old 03-24-2009, 03:51 PM
DDan's Avatar
Originally Posted by cpuerror View Post
DDan,
Thanks Assaf, that is a new record for support. .8A did indeed fix the download issue.
I have never seen CC only function that way before and my download from the scanner only contains the CC freqs. ???
Many thanks for your work on Freescan. I would not have bought a 396XT at this point in time if it weren't for your hard work.
73 de Dan/w6kru
Old 03-24-2009, 09:45 PM
DDan's Avatar
I am still having issues with the file I downloaded from my 396T. I can't figure out how to assign a quick key to the trunked systems. The system QKs that were used on 396T are dropped on the download. When I select the system in the browser there is no drop down box for assigning a QK. What am I missing?
73 de Dan/w6kru
Old 03-24-2009, 10:11 PM
cpuerror's Avatar
This tends to confuse people so please bear with me. Quick keys are set on the site level on the 996 which Freescan was designed around. Since the the 396T doesn't support sites, a site is created for you when you download. So click on the site, and that is where you set your QK and trunk frequencies etc.
If no sites appear when you download, then you have to redownload the .msi file and reinstall. Hope that helps.
Old 03-24-2009, 10:28 PM
DDan's Avatar
I have sites and can assign QKs to them. No problem with that. I was looking at the Complete Reference for the 396XT and it talks about assigning QKs to systems and sites. So you are telling me that I turn systems on and off by using site QKs? The reference seems to indicate a hierarchy of system/site/group QKs. I will go build a system from scratch and maybe that will clear things up for me.
73 de Dan/w6kru
Old 03-24-2009, 10:57 PM
DDan's Avatar
The system I built from scratch from the RR database works the same way. I will post a question on the 396XT thread on the other forum since I don't have the scanner in hand yet. The docs don't seem to match up with this.
73 de Dan/w6kru
Old 03-24-2009, 11:15 PM
cpuerror's Avatar
Conventional systems can be controlled by system QKs, trunk systems are controlled through site QKs. You cannnot lock out or turn off a trunked system. But you can turn the individual sites on/off.
Old 03-24-2009, 11:24 PM
DDan's Avatar
OK. Thanks Assaf. That sure makes sorting things by keys a mess huh? That answers another question I had.
73 de Dan/w6kru
Old 03-24-2009, 11:32 PM
cpuerror's Avatar
And thats cannnot with 3 n's, so you really can't do it.
Old 03-24-2009, 11:36 PM
DDan's Avatar
I'll remember that. The guys on the XT thread are going to tell me again pretty soon.
73 de Dan/w6kru
Similar Threads
Freescan APCO 25 site setup questions snakecharmer Scanner Programming Software 3 01-14-2009 01:14 PM
Help with FreeScan and Importing Frequencies Sjswing Scanner Programming Software 2 01-11-2009 05:00 PM
DPS questions for your serious DPSers... texasemt13 Texas Radio Discussion Forum 11 10-30-2008 12:52 PM
First time scanner user - WORTHY QUESTIONS Jon_in_Metairie General Scanning Forum 25 05-24-2006 08:21 PM
Questions and Answers about wireless phones Radiorick Tavern Archives 10 12-23-2004 06:11 PM
