Old 04-04-2009, 10:19 AM
Haley's Avatar
Default WIN96 NWS question
I was wondering if anyone used, or knew what the NWS SAME code search feature does, or how it works. I love using this program, and for some reason I have missed this feature. Thanks for any help, Mike
Old 04-04-2009, 10:25 AM
Haley's Avatar
Sorry guys, I should have posted this in the software forum probably. Mike
Old 04-04-2009, 10:31 AM
Sinister's Avatar
Moderator
Send a message via AIM to Sinister
Moved to the Software Forum
Thanks Glenn
RR Moderator
Digital Scanner Comparison Chart
NH Wiki
Old 04-04-2009, 11:30 AM
fmon's Avatar
Google same codes. Find your 6 digit codes for your area and list up to 10 codes in Win96. Also, set Priority Channel to On and enter your strongest of the 7 frequencies available.
Keep in mind (if you are scanning a busy bank), the scanner may miss the 1050 Hz tone.
Frank
RR Wiki Programming Shortcuts
Old 04-04-2009, 12:20 PM
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
Use this feature to enter the FIPS codes for the areas you most need the NOAA/NWS SAME warnings for. You may then also enter a text tag for each, say the County/Parish you listed ... In SAME standby mode your scanner will alert you to any alert broadcast by NOAA/NWS for that area. You then click to listen to the alert. Sometimes you may miss the Tone, sometimes you may click over fast enough to also catch this.
When the SAME alert is broadcast your scanner will sound a different alert tone for each type of warning, as well as display the type of warning it is.
Admin for AR, LA, MS, and TN
*RS PRO-96, RS PRO-92B, BC855XLT*
"Did I say something funny meow?"
"If a tree falls, do the squirrels get FEMA trailers?"
Old 04-04-2009, 12:47 PM
Haley's Avatar
Ok guys! Thanks for the help and replies, Mike
Similar Threads
Win96 programming question SouthSideScannerGuy Scanner Programming Software 3 08-22-2008 12:27 PM
Win96 Question mipsyop Radio Shack Scanners 1 08-07-2008 11:32 AM
Manual programming question manross Radio Shack Scanners 2 01-10-2007 10:31 PM
Win96 Extended Frequency Question xusmarine1979 Ohio Radio Discussion Forum 13 08-10-2006 10:39 PM
Win96 Key Question snjct2000 Scanner Programming Software 15 08-07-2006 12:35 PM
