Old 04-30-2009, 03:45 PM
Send a message via AIM to emmie
Cool Win96...what the.....?
Getting another headache!... I've been attempting to program my Pro96 with the Win96 software after hit and miss maunal programming. All systems were "GO", but the old Pro96 doesn't seem to receive the new imported data.
I am using the RS 20-047 cable. I tested it's com port location and setup by uploading DSP firmware. This little task worked fine. (Successfully received the "field" upgrade).
After my test of the USB cable and hookup, I proceeded to Win96 software. I started with some simple editing of initial global parameter changes (welcome screen, backlight, delay times, etc). Following guidelines, cilck import to scanner and so forth, the upload shows as being sent to scanner with it's running bar graph. I recieve the uploade "done" message, reboot the scanner only to find nothing has changed!!
After several attempts with subtle changes....still no edits have been written. Thus the headache.
I have tried with and without the 3 inch adapter cable. I have run through the devise manager and verified my com port being used is correct and enabled with no hot sync or other devises sharing it. I have tried disabeling the two-way edit return of the cable, I've tried the extra import time function and I have tried "saving as.." my edits and reattempted import...Keeerap! The scanner still isn't receiving the info.
Yes, the scanner is on during import attempts.....
Any ideas? .....Still pretty much a newbie...Dana (emmie)
Old 04-30-2009, 06:07 PM
When you upload from Win96 to the scanner, what (exactly) steps are you performing?
Does the scanner's display indicate that it's receiving data?
Old 04-30-2009, 10:26 PM
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 2_2_1 like Mac OS X; en-us) AppleWebKit/525.18.1 (KHTML, like Gecko) Version/3.1.1 Mobile/5H11 Safari/525.20)
Don is the best...
Old 05-02-2009, 10:06 AM
Cool
DonS,
Good AM. First of all, thank you for your reply!
After throughly reading the configuration menu within the HELP portion of Win96, I arrived at the problem. I unchecked the RTS line HIGH box and was then able to operate. The Win96 program is fantastic! I just had to slow down and read.
To date, I have not melted the old Pro down to a puddle of smoking plastic......yet, so I'll proceed with programming.
Again, thanks for your response.
Dana (emmie)
Similar Threads
RKI: RS USB cable Cat. No. 20-047 does not work with Win96 in Windows Vista MHZ Radio Shack Scanners 16 09-24-2008 11:22 AM
RR Sample download .csv file and Win96 zmuzak Scanner Programming Software 1 01-18-2007 02:58 PM
Don Starr Win96 typical turnaround time? norm25 Radio Shack Scanners 11 10-15-2006 10:55 AM
Win96 Help! Please Post your Oahu Scanner files or Win96 Screenshots here... Jamrock808 Hawaii Radio Discussion Forum 1 07-18-2006 02:26 PM
Win95 & Win96 zip files for Santa Clara City,County & norm25 San Francisco Bay Area Discussion 6 01-19-2005 06:00 AM
