Old 05-03-2009, 05:03 PM
Default Adding two objects to scan list using pro106 win 500
I recently purchased a pro 106 scanner. I cloned from a buddies scanner to mine. But I would like to add a couple of items to a scanlist that were left out. I have everything I need to do it except the knowledge. I'm using the win 500 software. Or where can I find info on how to use the software.
Old 05-04-2009, 07:11 AM
tonsoffun's Avatar
RR Moderator
Hi Tuffy,
I moved your thread to the software forum.
Welcome to RR
Ron
Ron
Moderator/DB Admin
Rules and Guidelines
Old 05-04-2009, 08:00 AM
Highpockets's Avatar
Try this, I hope it helps!
WIN500 - UtahRadio
Steve
BC780xlt ~ BC785D ~ PSR600
Old 05-04-2009, 09:38 PM
N8IAA's Avatar
Make sure you are in the scanlist you want to make a change. Click on EDIT, click on New Item at end. A new object appears at the bottom of the scanlist. Add your frequency, TGID, add your alphatag. you're done.
Larry
Pro-106, Pro-163, Pro-99, Lafayette 200A, ScanFare VHF 4Ch Xtal, FT-60R
Old 05-06-2009, 11:34 PM
Smile Thanks
Thank you Highpockets That's exactly what i was looking for. Thanks everyone who responded.
Old 05-07-2009, 07:44 PM
Default New issue
Ok I think I have the talkgroups covered. But when I load it into the scanner I get a "nothing enabled" message. I think I need to enter a TSYS. Do I do that manually or can I populate that from the software. I'm getting closer to figuring this out.
Similar Threads
Win 500 % Win 500 Remote Server Access btritch Scanner Programming Software 0 07-16-2008 09:00 PM
Adding TG using Win 500 program. gman51 Scanner Programming Software 3 04-04-2008 11:25 PM
Another 500/600 Qwirk joseph GRE Scanners 18 01-29-2008 07:43 PM
adding tlkgrp scan to Maxtrac 888 type2 ? mike28 Motorola Forum 4 11-08-2004 05:56 PM
