Old 05-03-2009, 05:32 PM
Default Help-programming pro-106
I'm trying to program the new FDNY UHF radio frequencies into my PRO 106 using the Butel ARC 500 software. The frequencies are not programming properly as listed below:
482.00625 shows as 482.000000
482.01875 shows as 482.012500
482.03125 shows as 482.025000
482.04375 shows as 482.037500
482.10625 shows as 482.100000
482.23125 shows as 482.225000
I know I'm missing something (changing some type of setting, but I figure out what it is.
Can someone please help.
Thanks.
Old 05-03-2009, 06:25 PM
Wiki Admin Emeritus
Setting the proper step size? I don't have this software or scanner, but that seems to be the bug here, at first glance anyway 73 Mike
Old 05-04-2009, 03:09 PM
thewenk's Avatar
Thanks.
For the PRO106, in the range from 470-512 MHz, I believe the standard step size is 12.5 kHz, so that is what the scanner will accept. WIN500 makes the same conversion as ARC500. Have you tried using those frequencies and see how well the scanner receives?
Pro-106 - The RadioReference Wiki
Dave
BCD996T, BCD396XT, PSR-600, PRO-106
DPD Omni-X Multi Band Antenna
DPD 700-1000 MHz LP Antenna
TinLee Diplexer
Old 05-04-2009, 05:32 PM
fmon's Avatar
When the 500 first came out Jeffrey Pryor made a spread sheet on Expert setting. Gommert included this sheet at bottom of his Help document. Radio Shack also included the sheet in106/197 owner manual.
I think if you check lower left of Global settings, Expert tab, you will find a check box for FlexStep. I doubt you will notice a change in the actual number, but this apparently sets the frequency correctly.
Frank
RR Wiki Programming Shortcuts
Old 05-04-2009, 05:42 PM
fmon's Avatar
Dave's Wiki link has Expert Settings spread sheet link in the scanner info. Oh Jeff is getting a lot of miles for his effort.
Frank
Old 05-04-2009, 07:49 PM
thewenk's Avatar
Enabling FlexStep is the answer and the correct frequency displays, at least in the software.
Dave
TinLee Diplexer
Old 05-05-2009, 07:04 AM
Thanks to all. I did change the setting for the flexstep and that did the trick
Agian, thanks.
Old 05-05-2009, 07:37 AM
fmon's Avatar
Agian, thanks.
Great!
Note for all, ARC500 gives credit to Jeffery for the spreadsheet, Radio Shack does not.
Frank
Old 05-05-2009, 08:04 PM
thewenk's Avatar
No matter how much you THINK you know, there is always something new to learn on these forums.
Dave
TinLee Diplexer
Similar Threads
Programming Pro 106 David3708 Scanner Programming Software 5 04-17-2009 02:57 PM
Thanks Mancow for the Pro 106 u sold me. madr68 For Sale Feedback Forum 0 01-22-2009 01:39 PM
pro 106 STARS programming by hand pogbobo Radio Shack Scanners 10 12-28-2008 05:26 PM
pro 106 programming ? RS2030 Radio Shack Scanners 2 12-23-2008 11:33 AM
Pro 106 File For N. Colo (ft. Collins) dougw65 Colorado Radio Discussion Forum 3 12-05-2008 01:03 PM
