Old 05-03-2009, 09:21 PM
Default Win 500 programming issues
I use Win 500 for my PRO 106. I am trying to program it for Brevard and Volusia Counties, in Florida. These are systems that are using the EDACS LTR, I think thats MA/COM. The problem I have is this: when I import the system I have to choose the sites that I want. There are several sites listed for each county. I choose all of them. Then, when I import them, I get a message stating that it may not work because there are too many sites. I didn't know what to do, so I simply accepted the error and imported anyway.
Needless to say that neither system works at all. All of the rest of my trunking systems work fine, so its clearly a site problem with each county.
Not sure what to do. Should I experiment by choosing 1 site at a time, or maybe I should install a complete system for each tower site and file them in different scan lists. I can do that but it shore would use alot of space. These counties each have an ungodly number of talkgroups!!
Any help would be great!!
Thanks,
Tom N4ETN
Old 05-03-2009, 09:40 PM
Multisite trunking isn't supported for EDACS systems. You should try only importing one site. You have to create a different trunked system object for each site.
Similar Threads
Win 500 Bug? btritch Scanner Programming Software 1 10-31-2008 10:33 AM
programming an uhf system into my psr 500 skip39 GRE Scanners 1 08-02-2008 06:19 PM
FTH-2070 Programming issues.. 10-95 All Other Receivers 1 07-27-2008 03:24 PM
gre 300 programming win 97 tommybza GRE Scanners 2 07-17-2008 03:40 PM
win 500 uploading ScanTheFreqs Scanner Programming Software 1 04-24-2008 04:36 PM
