Old 05-06-2009, 02:07 AM
Unhappy ARC160 Problem?
When trying to connect to RR through the ARC 160 software, it will not connect to the USA trunking databases. If I were downloading Canada or Austrailia, it would work just fine. I am getting an error message that says "WEB SERVICE error .. 8. Not enough storage is available to process this command." This only applies to trunking data. I've downloaded conventional systems just fine. Any ideas?
____________________________________________
PRO-97 PRO-160 PRO-162
Old 05-06-2009, 01:14 PM
still going on...
Old 05-06-2009, 02:11 PM
ok....I spoke too soon.... This is not the problem... as I have changed my password and I still have the original problem? Is something going on with the RR website? I can best be described as sporadic, with the emphasis on the downside. i.e. it doesn't work as much as it does work.. It will not allow me to select a specific system to download...and then it hangs up. Help.
The requested URL /apps/xml/sl=1 was not found on this server.
Apache/2.2.3 (Red Hat) Server at www.radioreference.com Port 80
Similar Threads
Could a scanner antenna cause cell phone problem? CHAWMAN24 Antennas and Coax Forum 1 04-16-2008 12:11 AM
Pro-83 And VHF-Hi problem bviator Radio Shack Scanners 9 03-20-2006 06:29 PM
Motorola Type II Scanning Problem w/ Pro-92 and 2067 TKennedy1975 Radio Shack Scanners 4 05-27-2005 09:44 AM
BC898T TV CH 8 Problem N9WP Uniden Scanners 4 11-30-2004 08:05 AM
Dead carrier problem back in NCC since the storm ptwtanks Delaware Radio Discussion Forum 2 10-02-2004 04:23 PM
