Old 05-12-2009, 12:05 AM
Unhappy Help with BC 346XT
Hey all just received my BC 346 XT scanner and having problems programming it. I am trying to monitor Orange County, California fire only a motorola type 2 trunking system. I used freescan and it loaded but I cant hear anything. What am I doing wrong hopefully someone can help me out.
Jay
Old 05-12-2009, 12:47 PM
Wiki Admin
If you are talking about this system...
Scanner Frequencies: Orange, County of (CCCS - Public Safety) Trunking System, Orange County, California
all you will be able to hear are those talkgroups in your neck of the woods with 'A' (analog). 'D' is digital, 'E' is encrypted (which nothing will receive). The 346 is an analog-only scanner. Of course, with that little antenna, your range is going to be limited to a couple of miles tops. You should pick the site(s) that give you the strongest signal
This should really be in the software forum (where I will have this moved) - however, without seeing your data file it's almost impossible to guess as to what is wrong. Two very common mistakes come to mind;
a. Allocating the wrong system type. There is a known bug in FreeScan .8E that causes the wrong system/site type to be downloaded from the database. Fixing it is as easy as changing it, then doing a 'replace' when you upload;
b. Forgetting to allocate - and enable - a system/site quick key and/or group quick key for each group (set of talkgroups).
You should take your file, zip (compress) it and attach it to your message. That way anyone also using FreeScan (I do) can look at what you have built and see if there's something amiss
73 Mike
Old 05-12-2009, 01:18 PM
burner50's Avatar
Bob Loblaw
Send a message via AIM to burner50 Send a message via MSN to burner50
If you like, I can move your thread to the software forum. You may get better answers there.
Jason
Moderator / Iowa Database Administrator
burner50@radioreference.com
Old 05-12-2009, 01:23 PM
Thanks burner please do.
Old 05-12-2009, 05:02 PM
Sinister's Avatar
Moderator
Send a message via AIM to Sinister
Moved to software forum
Thanks Glenn
RR Moderator
Digital Scanner Comparison Chart
NH Wiki
Similar Threads
New TAFL Search jfroot Eastern Canada Radio Discussion Forum 35 09-25-2009 10:22 PM
Trade Uniden Bc 796D for a Uniden 996T W9NES Old Classifieds Archives 2 03-10-2009 07:25 AM
WTT:Uniden Bc 796D for a Uniden Bc 996T W9NES Old Classifieds Archives 1 06-13-2008 01:02 AM
F/S Uniden BC 780xlt / BC 250d w/ Apco Card Yocuz Old Classifieds Archives 9 05-16-2008 08:57 PM
