Old 05-12-2009, 12:10 PM
Default WIN500 with Vista os
When I use Win500 software with Windows Vista OS, the information does not line up,or fit correctly in the boxes. The numbers or letters are cut off at the bottom. I want to purchase Win500, but I would like to know if there are adjustments that can be made in Win500 or Vista that will correct this problem.The entries made are not in the middle of the blocks, it is as if they are positioned too low in the blocks. I appreciate any help . Thank you. Ken
Old 05-12-2009, 12:18 PM
fmon's Avatar
Configuration Menu click User Interface.
Frank
RR Wiki Programming Shortcuts
Old 05-12-2009, 12:35 PM
Default Thank you
Thanks Frank,
I will try that when I get home.
Ken
Similar Threads
20-147 Cable, Pro-95, and Vista JohnSc1 Scanner Programming Software 5 06-03-2009 11:40 PM
Program Pro-106 with Win500 & RadioReference? TeamMcDonough Scanner Programming Software 2 03-18-2009 03:48 PM
Windows VISTA and radio shack serial port adapter vista install kd5dga Radio Shack Scanners 17 01-24-2009 09:28 PM
Chula Vista contracts with SDFD for dispatch services n6766j California Radio Discussion Forum 0 12-17-2007 04:46 PM
FT: Pro-99 and etrex vista GPS kg4omx Old Classifieds Archives 0 11-30-2005 07:41 AM
