Old 05-13-2009, 10:21 PM
Default Pro 2096 pgm cable ???
I have two serial port cables for programming my Pro-2096, On both cables been getting the following message; "expected to read back the data we just wrote-this failed. Ensure the correct port, supplied cable and scanner turned on."
I am using the latest win96 software, could my serial port have gone BAD?
mustang108
Old 05-14-2009, 09:40 AM
Not Posting
have you recently plugged th cable into a different USB port perhaps, Also the PCIF port on the scanner may have become loose inside the radio, check software & device manager & see if the comports are matching up. and try & check "use extended write time also
just reread you message , youare using serial cable so?? not sure, at least check in device manager & try differnt comports
Similar Threads
Pro 2096 for $200 to good to be true? It was!!! rqueen2229 Radio Shack Scanners 18 11-20-2008 07:51 PM
FS: PRO 2096 Digital Mobile Scanner - GTA WZ1 Old Classifieds Archives 6 09-26-2008 11:20 PM
FS: Radio Shack Pro 2096 and Pro 2006 n2pqq Old Classifieds Archives 8 09-08-2008 10:07 PM
Pro 2096 scanning speed plankeye Radio Shack Scanners 3 10-02-2006 11:50 PM
