Old 05-14-2009, 02:20 PM
kokomo1's Avatar
Question Butel Feature Idea
I had an idea and wanted to see if it was a good one. My Uniden scanners can enable/disable sites that have longitude/latitude entries when using a GPS.
Putting those in are slow and painful and while I might spend extra time for my everyday stuff, when I go on a long trip, I am too lazy to really program it in.
For example I went on a multi state vacation this past fall, I just divided up the trip into a dozen or so groups of 3 to 5 counties and enabled/disabled them manually as I went along. (I made a quick reference I atached to me visor.)
So what about having a feature wich can be enabled in the Butel software that would automaticlly add the geographic center of the county whenever you do an import.
Yes it would not be 100% accurate but would be close enough for most people. Any thoughts?
BCD396T | BR330T | BCD996T | BCT15 | BC370CRS | [SOLD] PRO-95 | [SOLD] PRO-79
Kokomo, Indiana Live Public Safety Stream | Kokomo-Weather | K9GTJ
Old 05-14-2009, 02:58 PM
Wiki Admin
While not quite what you are proposing, I understand the new version of the web service (which, currently, only ProScan and FreeScan supports) can import GPS data directly from the database, if it has it. So there's at least a partial solution to your problem.
The current service will be dropped as of the end of July- I have no doubt Gommert is sweating some bullets getting all his software converted over, otherwise he's going to have a lot of very unhappy customers.
73 Mike
Similar Threads
Butel Registration Problem JohnBreen Scanner Programming Software 4 06-27-2008 02:42 PM
BearTracker Warning Feature: Usefulness of.. letarotor Uniden Scanners 20 06-06-2008 09:04 AM
Butel Sofware rip off mrrikk Scanner Programming Software 12 12-20-2006 06:46 AM
Butel ARC330 and ARC396 .mem Files Not Working hotdjdave Scanner Programming Software 6 04-06-2006 09:31 PM
Butel Software and UASD files bonus1331 Uniden Scanners 2 01-17-2005 06:22 PM
