Old 05-25-2009, 10:52 AM
Default ID Tracker II - V3.0.0 Released
- Added support for TrunkTracker III scanners. ID Tracker II now supports the following scanners:
PSR-500/600, PRO-106/197, BCT8, BCT15, BC246T, BC250D, BC296D, BR330T,
BC346XT, BCD396T, BCD396XT, BC780XLT, BC785D, BC796D, BC898T, BCD996T
(also, non-US versions of these scanners)
- Added capability to delete system files from the Settings dialog.
- Made scanner control display text more readable.
- Added code to automatically restart the application when the scanner type is changed.
ID Tracker Mirror
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Last edited by brscanning; 05-25-2009 at 12:20 PM.. Reason: Added BC346XT and BCD396XT to supported scanner list.
Old 05-25-2009, 11:26 AM
joescanner's Avatar
Just another radio geek.
Will this support the BC346XT and the BCD396XT? What about the soon to be released BCD996XT and BCT15X?
Joseph Stein, KD7MLG
RadioReference Database Administrator for Oregon and Washington State
Old 05-25-2009, 12:07 PM
I omitted the BC346XT and BCD396XT support.
I have not seen the protocols for the BCD996XT and BCT15X yet, but if it does not greatly deviate from the older models, supporting these scanners should not be much of a problem.
Baton Rouge, LA
Old 06-05-2009, 03:25 PM
I have been running my BCD396XT and have only seen one problem so far. When a NAC code comes up on the virtual control window, where it should be reading NAC*** it is showing 000 with symbals above the zero's instead of NAC. Probably just needs to recognize alpha's in that area.
Old 06-07-2009, 11:17 AM
I don't have anyone using NACs in my area so I have not been able to work on this. If you would email me I will work with you to resolve this.
Baton Rouge, LA
Similar Threads
ID Tracker II - Version 2.0.0 Released - GRE Support brscanning Scanner Programming Software 19 11-25-2008 08:53 PM
ID Tracker II - Version 2.0.3 Released brscanning GRE Scanners 0 11-14-2008 05:34 PM
ID Tracker II - Version 2.0.2 Released brscanning Scanner Programming Software 0 11-07-2008 04:57 PM
ID Tracker II Released brscanning Scanner Programming Software 15 11-05-2006 01:17 PM
ID Tracker II Released brscanning Uniden Scanners 12 10-31-2006 12:35 PM
