Old 05-30-2009, 11:34 AM
Default Freescan band defaults settings
I'm using .9b with a 396xt, and I can't find the band default settings. Am I missing it somewhere?
Thanks!
YoShep
Old 05-30-2009, 11:37 AM
Wiki Admin
What do you mean by 'band default settings?' 73 Mike
Old 05-30-2009, 11:50 AM
The 396xt has a band default setting for mode and step size.
ie, I can change the factory 108-137 range from 8.33k to 25.0k step.
From the key pad,
Menu
Settings
Band Defaults
YoShep
Old 05-30-2009, 01:44 PM
Wiki Admin
That would be set on the channel level when you are editing frequencies in a group. Once you have defined your systems and sites then your groups are next. Things like step size, mode, alert levels, and a lot more are set up this way 73 Mike
Old 05-30-2009, 02:04 PM
cpuerror's Avatar
Band settings haven't been implemented yet.. The step size for the channel group is meant for the 246 & 230 only. As YoShep said, for now you have to use the front keypad.
http://scannow.org - Download FreeSCAN
Old 05-30-2009, 03:11 PM
No, there is a GLOBAL setting on the 396xt.
YoShep
Old 05-30-2009, 03:14 PM
Smile
You said "yet." Is that on the to do list?
YoShep
Old 05-30-2009, 04:03 PM
cpuerror's Avatar
It's one of those things on the To Do list, yes.
YoShep
Old 05-30-2009, 05:36 PM
Excellent,
Thanks,
YoShep
Tags
freescan
Similar Threads
Fire tone-out issues - Freescan / 396XT daveharpe Scanner Programming Software 0 05-09-2009 09:28 AM
996 settings ScanNEIN Uniden Scanners 5 02-23-2009 02:47 PM
Official Fire Tone-Out Discussion UPMan Uniden Scanners 643 08-31-2007 12:59 AM
What are the factory default AGC settings? powerhouse Uniden Scanners 7 12-17-2006 06:24 PM
396 AGC settings Balt area doctordave Maryland Radio Discussion Forum 0 04-08-2006 10:37 AM
