Old 05-31-2009, 08:34 PM
Default ARC XT DEMO Help Menue
I have downloaded ARCXT Demo but I cannot get the help menu to open the Softwear Manuel. How can I get it to open ? = Learning my way around the demo by trial and error will be quite a challenge. Also, when I go to upload to a scanner I get a message that the com port is not available or being used. How do I correct this ?
Old 05-31-2009, 11:09 PM
thewenk's Avatar
Since this is still in beta release the the software manual probably is not available yet.
You don't have the correct com port selected. Under the Scanner menu, select the Communication setup and then select "AutoDetect Scanner". Assuming everything is hooked up ok, the software will then detect the com port to which the scanner is connected and you should be good to go.
Dave
BCD996T, BCD396XT, PSR-600, PRO-106
DPD Omni-X Multi Band Antenna
DPD 700-1000 MHz LP Antenna
TinLee Diplexer
Similar Threads
Butel's ARC XT Beta Software sjlamb Scanner Programming Software 25 07-02-2009 02:07 PM
arc 300 demo not working NX1V Scanner Programming Software 5 08-26-2008 06:49 PM
Sticky Thread for MilAir II TinEar Maryland Radio Discussion Forum 4098 01-01-2008 11:21 AM
ARC 396/246/etc software limitation of 200 channels per group (conventional) brianfoy Scanner Programming Software 14 07-06-2006 05:14 PM
Holloman Air Show Freq's abqscan New Mexico Radio Discussion Forum 1 04-18-2005 11:55 AM
