Old 06-04-2009, 10:58 PM
Send a message via AIM to jdh08077
Cool FreeScan Issue - Fire Tone Out
I'm running version 9B of Freescan for my 396XT. I set up the fire tone out function off of the Set Scanner Option tab. I can see the setup in FreeScan, but it doesn't upload to the scanner. On the computer, I'm using XP Pro 32bit. Does anyone know if there is a setting in FreeScan software to inhibit Fire Tone Out upload, or did I stumble on a bug. It brings over all of my other custom scanner options, including SAME.
Old 06-04-2009, 11:06 PM
cpuerror's Avatar
There are a couple things you can check. Make sure that "Send scanner settings" is checked in the upload dialog box.
Also if you are using a file from a version prior to 0.9 it can sometimes cause hiccups with FTO. I would suggest creating a new file and trying to upload your FTO settings again. Downloading settings from the scanner and then saving the file should resolve it as well. Hope that helps.
http://scannow.org - Download FreeSCAN
Old 06-05-2009, 01:18 AM
Smile That Worked
I uploaded from the scanner and made a few changes then downloaded back to the scanner.
All my changes were there.
Thanks for you help
John
Similar Threads
AA County Fire Companies n3bxv Maryland Radio Discussion Forum 51 08-07-2009 05:03 PM
looking for your fire freqs make a trip mikeh Australia Radio Discussion Forums 12 02-16-2009 05:21 PM
60 new feeds added to my site jasonpeoria911 Streaming / Broadcasting / Audio Recording 7 01-11-2007 12:26 AM
frequencies wanted oneworld Connecticut Radio Discussion Forum 5 02-18-2006 04:22 PM
