Old 06-10-2009, 09:24 PM
Default ID Tracker II - V3.1.0 Released
- Added support for Network Access Codes (NAC).
- Increased frequency display to 5 decimal points.
ID Tracker Mirror
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Old 06-10-2009, 09:35 PM
DaveIN's Avatar
Thanks Dave!
Old 06-11-2009, 11:24 AM
ID Tracker Mirror
Dave,
Does IDtracker II support DIGITAL Mot type II systems??
Old 06-11-2009, 05:43 PM
Originally Posted by oilmillcharlie View Post
Dave,
It does if your scanner does. See the list of supported scanners on the web site.
Baton Rouge, LA
Old 06-11-2009, 07:29 PM
Cool
Dave, thanks for the update.
One note, I set up the new version with my BCT15 and the program doesn't initialize the radio when the Setup is set to "Trunktracker III"... it only works when its set to Trunktracker IV.
Old 06-12-2009, 09:41 PM
Although it says TrunkTracker III on the scanner, the BCT15 uses the TrunkTracker IV protocol. It's basically the same as the 996 without digital support. I may need to put that in the help.
Baton Rouge, LA
Old 06-14-2009, 02:33 AM
Send a message via Yahoo to wbigcount
thanks
Union Pacific Railroad Conductor
Kansas City Missouri, Omaha Ne, DeMoines IA.
Big C
Old 06-15-2009, 03:44 AM
Cool
Yeah or just change the drop-down menu to a list of scanners... might be less confusing.
Old 06-18-2009, 11:04 PM
Location: Nashville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud
Anyone one have it that when it records and they are done talking the record like on the idtracker screens flashes on and off? Then when I listen to the recording it saved there is no delay in between them talking, it is like continues talking, where when it works, there is about a 2 second pause between different people talking.
I had this happen before and cannot figure out what happened to make it to it and how to fix it.
I just changed over to a new PC and that is when it started happening. I had it happen before when I changed to a new PC but I was able to fix it. It is like the scanner stops talking to IDtracker when they are not talking on the radio. On the screen when the red recroding light gos one and off it going to tracking on the idtracker screen as well
Even if no one is talking, the hit counter keeps climbing and the record light comes on and off and keeps flashing till the scanner start to scan again.
So looks like a COm problem between the scanner and PC.
PSR-500 | Pro-96 | BCD996T | PSR-600
Webmaster http://westmichiganscan.com
ID Tracker Website
Old 06-20-2009, 12:53 AM
did some more testing and it is not IDtracker that is doing it. For some reason when I uploaded my Win500 file to the scanner, it did something with the freq I entered. I had to go into the scanner and through Win500 and enter my two control channels and then it worked. I have the latest version of Win500 so I have no idea what happened.
ID Tracker Website
Old 07-19-2009, 01:01 PM
Program is not working with my 996xt. Error message: Scanner Error. 396xt is working fine.
Old 07-19-2009, 01:22 PM
Could you please try the following so that I can troubleshoot the issue.
- Start ID Tracker II.
- Stop tracking.
- Press the F12 key to open the debug window.
- Click on Log then enable the "Log to File" option. The log file name and path will be listed in the debug display.
- Enable COM debugging under the Options menu item.
- Start tracking.
- Wait until the problem occurs and let it capture some data.
- Stop the tracking.
- Disable the "Log to File" option.
- Exit ID Tracker II.
- Email me the log file.
Baton Rouge, LA
Old 07-20-2009, 10:35 PM
brscanning, did you get my e-mail and logs about it not showing the correct CT tones in the log screen?
ID Tracker Website
Old 07-21-2009, 06:43 PM
I did get your email. I did not realize that you were using a GRE scanner so it will take longer to look into. I have been busy lately so I have not had much time to play with scanners and the software.
Baton Rouge, LA
Old 07-21-2009, 07:35 PM
zzdiesel's Avatar
Thanks for the update.
Uniden BCD996XT | Radio Shack Pro197 | Radio Shack Pro-2055 | Uniden BCT-15 - Mobile | Radio Shack Pro-92
Software: Win500, Win97, Win92, Proscan, Freescan & I.D. Tracker
Old 07-21-2009, 08:51 PM
mrkelso's Avatar
ID Tracker II - V3.2.0
000:00:01.456 BCSendIV - Timeout (MDL)
000:00:02.563 BCSendIV - Timeout (MDL)
000:00:19.560 BCSendIV - Timeout (MDL)
000:00:20.662 BCSendIV - Timeout (MDL)
000:00:27.701 KeyCode: 123 Shift: 0
I couldn't get it to work
Old 07-22-2009, 01:06 PM
mrkelso's Avatar
Got it working I had the wrong baud rate set.
Similar Threads
ID Tracker II - V3.0.0 Released brscanning Scanner Programming Software 4 06-07-2009 11:17 AM
ID Tracker II - Version 2.0.0 Released - GRE Support brscanning Scanner Programming Software 19 11-25-2008 08:53 PM
ID Tracker II - Version 1.17.0 Released brscanning Scanner Programming Software 7 01-19-2008 04:03 PM
ID Tracker II Released brscanning Scanner Programming Software 15 11-05-2006 01:17 PM
ID Tracker II Released brscanning Uniden Scanners 12 10-31-2006 12:35 PM
